Old 01-19-2018, 09:07 AM
givo givo is offline
Default High Temperature during take off in RV-7
I guess this issue has been already discussed many time in this forum . Nevertheless Im relatively young in experimental field and in RVs so I post the following question , hoping someone is so nice to give me some suggestion .
I have problems of temperature in my RV-7 180 CV . I have two CHT , one on the most cooled , one on the least cooled cylinder .
I have also a small door on the lower cowling ( I miss the English term , in Italian is flabello ) that can be open with a servo .
With this door open , during take off also in winter with externa temperature of 30 50 F , the temperature of the less favorable cylinder goes from 350-400 F to 450 F . The other more cooled cylinder will stay around 400 F .
After take off I usually level the aircraft quite soon reducing power as soon as feasible and until both temperature return to 350 F but it take quite a while .
Than I resume normal level flight at 75% power .
From now on temperature are relatively stable around 350 F but if I start to climb also starting from an altitude as 3000 ft the temperature of the less favorable cylinder goes to 400 F .
Question : there is a way to improve ventilation inside the cowling ? Shall I install second door on the lower cowling ? or may be shall I enlarge the bottom opening ? regarding the baffle they seems to sit quite tight with the cowling tank you for suggestions Giulio
Old 01-19-2018, 09:19 AM
N941WR's Avatar
N941WR N941WR is offline
What ignition do you have and what is it timed at?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-19-2018, 09:23 AM
N941WR's Avatar
flabello = Flap or "Cowl Flap" if on the engine cowl to help cool the engine.
"flabello" = "Flap" o "Cowl Flap" Se sul cofano motore per aiutare a raffreddare il motore.
Bill R.
SC86 - Easley, SC
Old 01-19-2018, 09:26 AM
My engine is a LYCOMING O-360-A1A with two magnet Marvel-Schebler Type MA-4 5 , standard timed I think
Old 01-19-2018, 09:29 AM
pefetto grazie , sei italiano ?
Old 01-19-2018, 10:30 AM
N941WR's Avatar
Sì, io sono del patrimonio italiano. I miei nonni dal lato del mio padre (Reppucci e DePresszió) sono stati da San Potito Ultra, Provincia di Avellino. Anche se sono nata e cresciuta negli Stati Uniti.
Dove in Italia vivi? (Non importa, ti vedo zona da Padova.)
(Ho anche cheat e uso MSWord per aiutare con la mia traduzione come il mio italiano è come un due anni).
Ciao
Bill R.
SC86 - Easley, SC
Old 01-19-2018, 10:32 AM
N941WR's Avatar
My engine is a LYCOMING O-360-A1A with two magnet Marvel-Schebler Type MA-4 – 5 , standard timed I think …
È il carburatore. Io sono curioso di sapere quali accensione avete e sono essi a tempo correttamente?
(In English: That is the Carburetor. I am curious about what ignition you have and are they timed correctly?)
Bill R.
SC86 - Easley, SC
Old 01-19-2018, 10:37 AM
Raymo's Avatar
Raymo Raymo is online now
Mine was similar until I installed the gear fairings but I also had to retard the timing of my P-Mag a couple degrees to help until the gear fairings were installed.
If fairings are installed, check baffling for leaks and confirm timing is correct for the mags and/or electronic ignition.
It is fine to have 400-425 in climb but should stay below 400 (380, ideally) in cruise. Mine cylinders run 360-390 in summer temp cruise, depending on mixture setting.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 01-19-2018, 10:42 AM
Mel's Avatar
Mel Mel is offline
Are you sure that the "eyebrows" are installed in the upper cowling over the inlets? If these are missing, it will cause overheating at high AOA.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 01-19-2018, 11:29 AM
S, io sono del patrimonio italiano. I miei nonni dal lato del mio padre (Reppucci e DePresszi) sono stati da San Potito Ultra, Provincia di Avellino. Anche se sono nata e cresciuta negli Stati Uniti.
(Ho anche cheat e uso MSWord per aiutare con la mia traduzione come il mio italiano come un due anni).
Ciao
molto bene grazie delle info , io ogni tanto vengo in US per lavoro ( pharma ) ciao Giulio
