Old 01-17-2018, 03:36 PM
azflyer21 azflyer21 is offline
Default Rudder Leading Edge Started
Today I set up my bench to roll the Rudder leading edge. I successfully finished 2 sections, now that I'm comfortable with the process I should be able to finish the rest tomorrow.
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N902X reserved
RV-14a Empennage Done
QB Wing QB Fuse inprogress
Build Log
Old 01-17-2018, 08:03 PM
Eztroller Eztroller is offline
Looks good. I read your blog and had the same issues using the tape on the trailing edge.
Old 01-18-2018, 06:57 AM
Did you do anything to close the gap in the Trailing Edge? I talked to Van's and they said it will not affect flight performance, but it will bother me knowing I have a few gaps.
Kevin Lippert
Sold
N902X reserved
Build Log
Old 01-18-2018, 11:41 AM
goatflieg's Avatar
I had a very similar setup on my work table for rolling. It works very well.
Martin J Filiatrault
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Dues paid for 2018... extra payment included for psychological therapeutic services rendered.
_______________________
Old 03-31-2018, 05:49 PM
Bernard Hartnell Bernard Hartnell is offline
Thumbs up Flush rivets
Besides several attempts at reforming the leading edge of the elevator; I noticed my nemesis were a few ill placed round head rivets inside the aft of horizontal stab. So I drilled them out, countersunk and installed flush pull rivets. Problem solved!👍
Plans may now have been revised to correct the close tolerances.🤷🏼*♂️
