Old 10-17-2017, 01:23 PM
n74846 n74846 is offline
Default Throttle Return Spring
I just replaced my fourth MacFarlane spring (245 hrs. TT) and called Van's to order more. I was told they are suspended and unavailable at this time. I asked for details but none were given. Is anyone aware of any internal review of the product? There seems to be a recurring theme in the posts.
Steve at BCT
Flying a built ELSA
Old 10-17-2017, 03:11 PM
alexe alexe is offline
Steve,
I stopped breaking throttle springs after I had the prop dynamically balanced. Been well over a year now with no further issues. Regarding the replacement springs, you might want to call MacFarlane directly.
Alex
Alex Erdelyi
RV-12 #120758, N912AE
Flying as of 4/28/15
Paid through December, 2018
Old 10-17-2017, 05:51 PM
Use of the currently supplied spring is being reviewed... more on that in the future.
In the mean time, the unavailable status has been changed so there is a limited number of the current part # available from Van's for replacement parts.
Scott McDaniels
Hubbard, Oregon
Old 10-17-2017, 08:21 PM
Thanks for the update and balance suggestion. The prop was dynamically balanced upon certification, 245 hours ago. What is the frequency recommendation?
Steve at BCT
Flying a built ELSA
Old 10-17-2017, 10:36 PM
Try Home Depot. After 5 years mine are intact and donít cause throttle creep.
Old 10-18-2017, 12:36 PM
Steve,
If the dynamic balance was done properly, I would think it would be good until the prop was disturbed somehow (re-adjustment of the pitch, etc).
Like you, I had gone through four or five springs. The person I spoke to at McFarlane suggested a prop balance if it had not been done. I was skeptical, but had it done anyway. It cured the problem for me.
Alex
Alex Erdelyi
Old 10-18-2017, 07:36 PM
Thanks Alex. Among other remedies I will invest in another dynamic balance. I'm sure that will improve things.
Steve at BCT
Flying a built ELSA
Old 10-18-2017, 10:22 PM
vernon smith's Avatar
vernon smith vernon smith is offline
I must have a one off. I purchased an RV-12 a month or so ago and it's throttle spring does not return the throttle arm to idle, rather it does it's level best to send it to about three grand every chance it gets.
Old 10-19-2017, 06:24 AM
JBPILOT JBPILOT is offline
Default Vern - -
That's what they are supposed to do. Springs pull to open.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-4-18 )
Old 10-19-2017, 09:23 AM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Depending when it was fabricated...you want the newer throttle cable,as it fixed the constant chase of the throttle creep.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
