Old 10-08-2017, 07:24 AM
jthocker's Avatar
jthocker jthocker is offline
Default Kavlico sensor wiring
Does anybody know the source for the male plug and wire connectors that Kavlico uses? I would like to crimp the the pins directly to the shielded wire from the engine module without splicing onto the incredibly huge wire supplied with the sensor.
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 10-08-2017, 07:44 AM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Looking
I did exactly that during my build - didn't want to splice the included pigtail. Let me dig around and see if I can find where I ordered them from.
Dan Langhout
2019 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
386 hours and counting . . . .
Now based at Moontown (3M5)
Old 10-08-2017, 08:03 AM
Christer's Avatar
Christer Christer is offline
Jon, check with me on Monday. A customer of mine found the pin P/N and so I just re-pinned the connector to avoid the splice. I might have that P/N at work.
Christer
Director of Maintenance, SteinAir Inc.
RV-8 Completed
Old 10-08-2017, 08:32 AM
jthocker's Avatar
Thanks Christer. I'll call you then.
Jon Thocker
Habitual Offender
Old 10-08-2017, 09:26 AM
krwalsh krwalsh is offline
Default Delphi 150 Connectors
Those are Delphi Metri-Pack 150 Series connectors. The Mouser part number is 829-12065287 for the body and 829-12089290 for the crimp on contacts. Before you mess up a handful of parts like I did, you assemble them by threading the wire through the connector body, crimp the terminal on, then slide the terminal back until it clicks.
Kevin R. Walsh
Cozy Mk-IV
Last edited by krwalsh : 10-10-2017 at 12:53 PM. Reason: Added detail and Web Links
Old 04-16-2018, 06:54 PM
dbaflyer dbaflyer is offline
Is it possible to disassemble my existing connectors? I tried by putting a slim piece of metal into the back to collapse the latch and pulling the wire forward through the front, but can't seem to get it loose.
I have the replacement crimp contacts so was able to see where the catch tab is located.
Denis Sailer - Eastern Iowa
RV9a builder - Finish Kit in progress
Old 04-16-2018, 08:35 PM
pilot2512 pilot2512 is offline
Yes, you can disassemble the old pins. I started with a paper clip that I ground down flat on 2 sides. then I dropped it and couldn't find it. Ended up using a hair pin. much wider and strong. I can send a pic if you give me an email address. You have to remove the rubber strain relief and release from the back side.
Jay
Jay
RV-9A
Empennage complete.
Wings complete.
Fuselage in progress
Wiring in progress
2018 Donation made!
Old 04-16-2018, 09:09 PM
https://www.google.com/search?ei=Hlf....0.MO15HEpI83I
Old 04-17-2018, 05:50 PM
I am trying from the front like this picture shows. Not having much luck this way or from the back.
https://photos.app.goo.gl/VNdZEYfaLKlgJkAC2
This is the tool I made:
https://photos.app.goo.gl/iNd9SHd2UDevPcVq1
https://photos.app.goo.gl/7vPSMKIb0L24CkHu1
Old 04-17-2018, 06:13 PM
the tang points forward. you have to go from behind and push forward.
Jay
RV-9A
Empennage complete.
Wings complete.
Wiring in progress
2018 Donation made!
