Old 04-24-2017, 09:22 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Default Rusty Crawford's RV7A with SDS EFI
This is Rusty Crawford's beautiful RV7A from Friendswood, TX just after he painted it.
Rusty is one of our highest time EFI customers, having started out with Subaru power originally, migrating to Lycoming power a few years back and now upgraded to a full dual EM-5 system. I believe he's approaching 1700 hours now with EFI. He's been extremely helpful in giving us feedback, new ideas, testing and helping other SDS customers in the Friendswood area.
Rusty is an all around, super talented, super friendly guy. Happy to be associated with him and to see his airplane painted in this gorgeous paint scheme. Nice work!
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 427.8 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 05-05-2017, 11:32 AM
kentlik's Avatar
kentlik kentlik is offline
Ok, so that green is the green I want on my plane! What, where, type...how can I get a hold of Rusty?
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 05-05-2017, 11:41 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Nice
Beautiful Plane....
Looks like Quality workmanship as well....very crisp.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 05-05-2017, 11:47 AM
Chkaharyer99 Chkaharyer99 is offline
Ross,
Beautiful airplane!
Can you tell us about the electrical architecture Rusty uses? Things like, how many batteries, alternators, buses...
Is he using the dual channel EM5?
As I understand it from a recent communication, the EM5 also drives the electronic ignition eliminating the need for the CPI. Is that correct?
Charlie
RV-8
Old 05-05-2017, 12:13 PM
Ironflight's Avatar
VAF Moderator / Line Boy
We used to live across the runway from Rusty - great guy, a d a real "motor-head" - an excellent person to be giving feedback on engine stuff. Glad he's giving you feedback Ross - a perfect guy to be putting on the hours.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-05-2017, 12:21 PM
N941WR's Avatar
N941WR N941WR is online now
Paul
I got to know Rusty when I was working in Houston a few years back and everything said about him is spot on.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-05-2017, 12:56 PM
rv6ejguy's Avatar
Originally Posted by Chkaharyer99 View Post
Ross,
Beautiful airplane!
Hopefully Rusty will pipe up on the electrical system layout when he gets some time.
Yes, he's using the dual EM-5 ECU setup. The EM-5 can do both EFI and ignition control together. On the 4 cylinder, dual setup, each ECU has its own crank and MAP sensor and runs one set of plugs. We can switch injector control between either ECU.
Old 05-07-2017, 01:47 PM
Thanks Ross.
When using the dual EM-5 configuration can just one SDS LCD Programmer be used or wold two be required in that situation.
Charlie
RV-8
Old 05-07-2017, 02:51 PM
Toobuilder's Avatar
A dual programmer is available. Single control head; controls both boards.
Michael Robinson
______________
RV-8 - Flying
Old 05-07-2017, 03:08 PM
rv6ejguy's Avatar
Thanks Ross.
As Toobuilder said, SDS offers a special programmer (single unit) which can access both ECU boards with the flick of a toggle switch. No need to unplug cables and switch between ECUs, which is a pain. This also allows the 6 cylinder folks with the individual fuel trim option to trim cylinders 1,2,3 on the primary and 4,5, 6 on the backup as they share tasks when in the Normal mode.
