Old 03-24-2017, 06:51 AM
bernsbm bernsbm is offline
Thanks Rich, much appreciated!
Barry
Old 03-24-2017, 07:22 AM
joedallas's Avatar
joedallas joedallas is offline
Default Ray Allen Position Indicator
I added a Ray Allen Position Indicator to my flap control arm and it will send the information to the Garman G3Touch and show the position of the Flaps
The Sensor wires to pins 30,31,32 on the GEA 24 ( the sensor is about $35.00 ).
You can also add a switch to one of the Discrete inputs on the GEA 24 0n on pin 40 ,41,42 or 43 and it will can send a output to the master caution on pin 44.
SkyView may have a similar system.
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 04-18-2017, 08:48 PM
dick seiders dick seiders is offline
Am I missing something here or am I the only RV12 driver that never uses flaps on takeoff? I mean the thing just about jumps into the air. Just sayin.
dick seiders
Old 04-18-2017, 10:04 PM
rgmwa rgmwa is offline
Try the flaps. You will be even more impressed.
rgmwa
120346
Old 04-18-2017, 10:22 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
dick seiders
Put in one notch of flaps...and you'll be even more impressed!! But I hear you; also, it precludes from busting through "Flap Over speed"! Especially if all you use is a nice surfaced..long runway. Soft/grass strip, use your flaps to destress your landing gear.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 04-18-2017, 10:40 PM
Phantom30's Avatar
Joe Dallas
Joe...mind sharing part #s and some pics (if you have them). Sounds like a good mod.
I'm just finishing my "Bender Baffle" and VR relocate to fwf (right of original position w/air scoop/enlarged air feed to regulator enclosure) and change to SH w/step voltage charge cycle.
Ric Dickison
307 (CAB) Phantom
Tho RVN)
2018 Dues Paid
Old 04-26-2017, 02:35 PM
Ernie Ernie is offline
Additional information for those adding a flaps widget to Skyview EFIS.
I attempted to add a position indicator to my Dynon Skyview Classic in my RV-12 per directions posted by RDupee. He stated [connect to Pin 9 of the 37 pin connector on the WH00045 “Options harness” that plugs into the AV 5000]
In my case, I found that that Pin 9 on the options harness and the AV5000 does not connect to the EMS Module and therefore it would not work for me.
I ended up connecting my flaps position limit switch wire directly to the EMS C37-9 pin, bypassing the AV5000. This allowed me to complete the task successfully.
Old 04-26-2017, 07:02 PM
RDupee RDupee is offline
Ernie, you are correct.
I apologize for the error in my previous post above. Thanks for spotting the mistake.
In my Skyview system, the wire from the Flaps micro-switch goes directly to pin 9 on the EMS 37 pin connector.
Rich D
1980 Evans VP1 completed, sold.
1995 Avid Speedwing completed sold.
RV-12 120259 First flight July 2014.
RV-10 kit started Feb 2017.
Old 04-27-2017, 05:54 AM
joedallas's Avatar
Default POSITION SENSOR
The Ray Allen Company
POS-5, POS-7, POS-12 ... POSITION SENSOR
http://www.rayallencompany.com/products/indsens.html
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 04-27-2017, 08:09 PM
Phantom30's Avatar
Joe Dallas
Joe..which one of the three did you use, and how hooked up to flap handle?
Ric Dickison
307 (CAB) Phantom
Tho RVN)
2018 Dues Paid
