Old 06-18-2016, 10:46 PM
cwharris cwharris is offline
Default Pin Numbers for GMU 22
Does anybody know which wire goes into which numbered socket for the GMU 22 magnetometer connection plug? I got the downloaded pin layout for the GMU 22 but I just don't know which colored wire is being used for which function. Vans sends you the wiring harness but doesn't send you a diagram showing what each wire is intended for.
Waylon
RV-14A Kit S/N 140175
Ordered Empennage Kit on 8-01-14
Ordered Wing Kit on 6-24-15
Reserved Tail# N814WB
Old 06-19-2016, 09:42 PM
Does anybody know?
Waylon
Old 06-19-2016, 09:53 PM
sibriggs sibriggs is offline
Default Download a copy of the G3X install manual for more info
Pin Name I/O
1 SIGNAL GROUND --
2 RS-485 OUT B Out
3 SIGNAL GROUND --
4 RS-485 OUT A Out
5 SPARE --
6 POWER GROUND --
7 SPARE --
8 RS-232 IN In
9 +12 VDC POWER In
Steve Briggs. RV9, G3x, G5, VPX, GTN625, A&P, IA, CFII
Old 06-19-2016, 10:03 PM
Thanks for the reply but what you listed is what the downloaded installation manual has which I have. My problem is that I don't know which wire is the
1 SIGNAL GROUND --
2 RS-485 OUT B Out
3 SIGNAL GROUND --
4 RS-485 OUT A Out
5 SPARE --
6 POWER GROUND --
7 SPARE --
8 RS-232 IN In
9 +12 VDC POWER In
I didn't build the wiring harness so I don't know which wire is being used for each of the listed items.
Can somebody put which colored wire to use next to the list above so I can place the correct wire in each of the 9 sockets.
Waylon
Old 06-20-2016, 05:19 AM
tomhanaway tomhanaway is offline
Maybe I'm missing something obvious enough here, but you need to check each instrument that the magnetometer is supposed to be connected to.
I.E., an rs-232 tx on the magnetometer should be connected to an rs-232 receive on whatever instrument it's supposed to be connected to. The color is not an automatic guide because it really depends on what it's plugged into on the other end. The color of the wire is a guide to assure you that you're working with the correct wire from the other connected end once you've identified it.
As you do each wire, you can then write down the color to remind you during future maintenance. Personally, I like to put a small tag on each wire to remind me of which pin it's going into.
Tom
Tom Hanaway
Moved to Murphy, NC
RV-10/N518TP-sold
repeat offending-8A N116TP-Now Flying
based in Copperhill, TN 1A3
Old 06-20-2016, 07:27 AM
I'm sorry I guess I forgot to mention that I don't have any of my Instruments bought yet. What I'm trying to do is put together or finish as much of the Wings and the Wiring as I can before I start on the Fuselage.
So therefor all I have is just the Wiring Harness with no map or guide as to what each wire is being used for that is until I get to the stage of wiring all the instruments but that will be a long time from now.
Waylon
Old 06-20-2016, 09:48 AM
Ok, easy then.
Just put each pin/wire into the magnetometer plug. At the other end of the harness, label each wire with the pin it's plugged into.
Either function (Rs-232 tx) or pin #. When you get your instruments, the schematic for each instrument will tell you which pin to connect.
It's all a learning curve.
Tom H
Tom Hanaway
Moved to Murphy, NC
RV-10/N518TP-sold
Old 06-20-2016, 10:17 AM
smash smash is offline
I started to layout the wing wiring harness and ran into the same problem. Then I started researching what wires are actually needed and discovered that the strobe lights I'll be installing should be wired with shielded cable. There are no shielded cable pairs in the supplied harness. The closer I looked at the Van's provided harness the more questions I got. Until Van's better documents the electrical system or until I finalize my panel and instruments I decided it was best to move on.
I left the bottom skins off the wings for the time being and went to work on the fuselage. There's plenty of tasks yet to be done before I have to worry about closing up the wings...
http://www.smashsrv-14build.com
Old 04-08-2018, 09:00 AM
Stockmanreef Stockmanreef is offline
But not all the pins are numbered on the socket. Numbers 1 and 9 are not labeled and it is unclear if 5 is the bottom hole or the middle hole.
The socket seems to be sort of randomly numbered.
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 04-08-2018, 09:49 AM
az_gila's Avatar
az_gila az_gila is online now
Smile
Yes, it does seem sort of random.... this might help -
https://www.mouser.com/datasheet/2/4...K1-1246748.pdf
Not sure whether to count clockwise or anti-clockwise - depends on male vs. female.
PS pin 5 is in the middle...
MORE -
PDF Page 33 here is much easier to read... https://www.mouser.com/pdfdocs/CPC-Catalog.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
