Old 10-10-2015, 03:57 PM
WingedFrog's Avatar
WingedFrog WingedFrog is offline
Default Check this at your next annual
During my annual inspection I caught a broken bracket under the ignition module. I caught it by chance just because the vibration had created a polished crack that reflected my torch light. Very tight place, no easy access for repair and after finding how this bracket was made originally by Rotax (by bending 90 deg a pretty thick piece of Al), I decided to fabricate one (out of an Al angle) that should be less likely to crack. I suspect that I missed this broken bracket at my last annual because it was not polished enough...
Here is the faulty bracket with the new one I fabricated:
Here is the location where the bracket can be inspected (the new bracket shown here after repair):
You can easily understand why this cracked bracket might be difficult to detect (although I found afterward that pulling the ignition module up will show the crack once the bracket is broken)
Builder's name: Jean-Pierre Bernoux
Sport Pilot
Kit # 120395 N124BX
Flying as of 9/11/2013
Builder's Blog:http://vieilleburette.blogspot.com/
EAA 1114
Old 10-10-2015, 04:15 PM
Mike H Mike H is offline
You really shouldn't use a torch within 50 feet of flammable liquids such as gasoline...just sayin.
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
Old 10-10-2015, 04:44 PM
DHeal DHeal is offline
I believe Jean-Pierre is from either Canada or France - a "torch" is a flashlight to them.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 700+ hours (as of Nov 2018)!
VAF donation through June 2019.
Old 10-10-2015, 05:13 PM
WingedFrog's Avatar
Excuse my French! (In French, torche is a flashlight).
Still, that was funny!
Sport Pilot
Kit # 120395 N124BX
EAA 1114
Old 10-10-2015, 06:25 PM
I know what he meant...just joking. Glad you found the cracked bracket. That new bracket should do the trick.
Mike Hammond
A&P IA PPL ASEL
Old 10-11-2015, 05:28 AM
Hotscam Hotscam is offline
On my 12 the same bracket broke at about 400 h.
**** of a job to fit a new one.
Jack Netherlands
PH-SEP and PH-SES
RV12 #120519 and #120790
Hobbs 700+ hours and 400+ hours
Dual SV1000 Skyview 15, Pocket FMS and Powerflarm 6.0 (ADSB)
Old 10-11-2015, 07:44 AM
n233va n233va is offline
Default Same Broken Bracket
I also had the same broken bracket on the ignition module at 325 hrs.
Old 10-11-2015, 08:54 AM
WingedFrog's Avatar
Jack and Bob: are you sure about the number of hours when your bracket failed? As I mentioned, the failure may go unnoticed as there is little consequences to it. Indeed the ignition stack is set on the top of 3 "silent blocks" (an other French term?) of generous dimensions regarding the mass they support. Only one of these rubber dampers is using this type of bracket, the two others have a sturdier attachment. What I don't understand is why Rotax, with all it's mechanical wherewithal, is using a bent piece of thick aluminum for a bracket.
Sport Pilot
Kit # 120395 N124BX
EAA 1114
Old 10-11-2015, 09:16 AM
curtis's Avatar
curtis curtis is offline
I see two possible issues with your new bracket;
1 - It looks like it is not the structural Al angle, no radius in the inside corner
2 - There appears to be a notch in the inside corner of the new angle, which may be a new failure point.
My questions are only based upon the image and may not be accurate.
RV-6A Slider
550 hours +
Build it light and cheap
Old 10-11-2015, 11:19 AM
My question, is an aluminum angle as strong as bent aluminum? Maybe it is stronger? I do agree the angle in the picture does not look like structural angle.
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
