  #41
Old 03-13-2018, 09:48 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Here's a photo of the return fitting location on my RV10. Bulkhead fitting sealed with Earls Stat-o-seals on both sides.
Turbo Subaru EJ22, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 424.4 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 03-13-2018, 10:20 AM
erich weaver's Avatar
erich weaver erich weaver is offline
I wasnt familiar with the stat o seal product. Good idea. Here is the link
https://www.summitracing.com/search/...e-stat-o-seals
erich
Old 03-13-2018, 07:28 PM
RandyAB RandyAB is offline
Are they easy to retrofit on a quick build tank that is already sealed?
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
Old 03-13-2018, 07:34 PM
rv6ejguy's Avatar
My wings were already built when I put my return fittings in. Unibit, vacuum cleaner through the sender hole with some 3/4 heater hose attached to grab the chips. Short wrench through the sender hole to grab the nut. Maybe took an hour to do both sides.
Old 03-16-2018, 06:23 PM
onebounce onebounce is offline
Originally Posted by steve murray View Post
This is what I did based on researching through various posts. Use this with caution as I have yet to install the wings to the fuselage.
Steve
Hi Steve - unfortunately your picture/link doesn't seem to show - can you re-post ?
Many thanks
Andy
Old 03-16-2018, 06:27 PM
Originally Posted by rocketman1988 View Post
There are photos and descriptions in my build log on this topic.
mykitlog.com
Search for Sunman, Indiana. I am the only one building here...
Thanks Bob - good to get a view of this. Looks like your return line entered the fuse near the top of the wing root - do you have any dimensions for the locations or a picture of the location ?
Many thanks, Andy
Old 03-16-2018, 07:25 PM
Default Pix
I will try to get some pix tomorrow...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 04-03-2018, 01:38 PM
thoma015 thoma015 is offline
***this if for a RV-7***
So I finished my first (right) tank and I installed a 1/4 in return line (the same as the fuel vent line). Im assuming this is no good or is it ok with a IO360?!
Is it possible to just plum the other tank (left) with a 3/8 fuel rerun line and only have fuel return to this tank? IE is it possible for the engine to draw fuel from the right tank but return the fuel to the left tank?
If thats possible i could away placard the aircraft to run first on the left tank so it doesn't overfill.
-Hawk
Old 04-03-2018, 02:38 PM
rv6ejguy's Avatar
You should return fuel to the selected tank. The return flow at idle is around 99% or about 1 gal/min. The 1/4 inch return is probably ok if you avoid a lot of 90 degree fittings on the way to it.
