Old 03-05-2015, 03:21 PM
Lynnb's Avatar
Lynnb Lynnb is offline
Originally Posted by rocketman1988 View Post
I think each application is going to be different depending on the system being used and personal preference. In my case, I am using the EFII fuel injection and ignition, so for the fuel system I used:
EFII double electric fuel pumps mounted in the tunnel
Two EFII pre filters mounted one under each seat
Andair duplex fuel selector valve and extension
EFII Pressure Regulator...mounted on firewall
Two 1/4" NPT aluminum flanges, one for each tank return
Closed end blind rivets for flange installation
Firewall bulkhead fitting
Tunnel bulkhead fittings
Fuselage bulkhead fittings
B Nuts and sleeves
5052 aluminum tube for lines
Adel clamps
And a substantial amount of time to fabricate the lines
If I did it again, I would probably just get Tom at TS Flightlines to make all the lines.
Thanks, right now my biggest concern is the fittings for the return lines to the tanks, I'll make other decisions a little later. I just didn't want to get the fuel tanks closed up and then find out there was something I missed. That's one of the frustrating things about this project is I almost feel like I need to have it all planned out from start to finish, just when I think I'm sailing along, bam have you thought about X. Owell, one rivet at a time.
Lynn
Old 03-12-2015, 12:00 PM
majuro15's Avatar
majuro15 majuro15 is offline
FYI, the VA-141 fuel pick up flanges are threaded such that they have be mounted from the inside of the tank. They will only fit through the sender hole with a bit of grinding and then you have to find a way to hold them in place with proseal while you rivet them. I found the standard AN bulkhead union to be easier. I'll post pics soon.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
RV-10 Fuselage under construction
N1017H Reserved
EAA #: 1106970
2018 VAF Dues Paid!
Old 03-12-2015, 12:49 PM
Lynnb's Avatar
Pictures would be great, my tanks are still open so all options are on the table right now.
Lynn
Old 03-16-2015, 10:17 PM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
Default Our Fix
So, we debated about the best way to fix this on our tanks. Taking the tanks off, going through the back baffle, attempting to do what Tim did and go through the fuel level sender hole. In the end, we decided to make a nice clean hole where it could be serviced if need be. Moved the return port, used sealed blind rivets, sealed the HECK out of everything and are about to retest for air tightness.
Hopefully this will be the end of it. it isn't super pretty, but no one will see it... except here....
Lesson Learned.
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Lead on the
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
"so I got that going for me... which is nice."
2017 Dues Paid"
Old 03-20-2015, 09:25 AM
johngoodman's Avatar
johngoodman johngoodman is offline
I drilled a hole high, and forward, with the same cautionary vacuum and grease method. Then, I snaked a long piece of wire through the hole and out the fuel sender hole. I put all the "inside" fittings on the wire, and pulled them into the hole (already prosealed). A washer on the wire pulled the fittings in place. Attached the "outside" fittings, and waited for the proseal to dry. Pulled the wire & washer back out the fuel sender hole, and closed it up.
John
John Goodman - 40572
First flight was 25 June, 2011
N711JG
Old 03-20-2015, 08:02 PM
majuro15's Avatar
I was able to do the final test on my tanks tonight after finishing my modifications. Here's a picture of the right tank. The return line is the fitting closest to the leading edge. I also replaced the phillips head screws with socket head cap screws.
www.N1017H.com
N1017H Reserved
EAA #: 1106970
2018 VAF Dues Paid!
Old 01-24-2016, 08:12 PM
ERushing's Avatar
ERushing ERushing is offline
Default Tim - Quick Question
Resurrecting this old thread.
Tim - What fitting did you use for your return line? I'm planning to blatantly plagiarize your work!
Thanks!
Eric Rushing
VS, Rudder, HS, Elevator, Tailcone - Complete
QB Wings - Complete.
QB Fuse - In Process. Tail & Fuse are one.
Molalla, OR
Old 01-24-2016, 10:05 PM
stamper stamper is offline
For anyone interested I just took my senders out 2 days ago because the guy I bought the 1o from had return lines put right in the sender unit itself. I do not need the return lines so I ordered new senders and will be installing them Monday and then putting my wings on.
I think the way he did would work fine but it was interesting how he did it right in the face of the sender itself.
2016 dues paid
RV10 Started Jan 2013
DAR sign off April 23rd 2016
PA-18
PA-46
Cessna 172 and T182RG
Old 01-24-2016, 11:39 PM
digidocs's Avatar
digidocs digidocs is offline
Stamper,
That's very clever. If you have an opportunity to take a photo of sender return setup, I'd love to see it.
Take care,
David
Old 07-06-2016, 06:41 AM
rdamazio's Avatar
rdamazio rdamazio is offline
Originally Posted by digidocs View Post
digidocs, what's the flange you used here?
Thanks!
Rodrigo Damazio Bovendorp
San Jose, CA
RV-10 builder #41623
Build log at http://www.airplane.build/
VAF dues paid
