Old 06-15-2014, 04:13 PM
bschweinberg bschweinberg is offline
Default Left Elevator Rear Spar Riveting
Page 9-20, Step 9 of the empennage plans say to rivet the E-01410 Trim Tab Reinforcement Doubler to the E-00902-1L Rear Spar using AN470AD3-3.5 rivets.
1. How did others rivet these three rivets? Did you get a bucking bar into the trim access cavity?
I would think that blind rivets for these three holes would be fine. Did anyone use blind rivets instead? If so, what did you use?
Bill S.
Builder #140100
Old 06-15-2014, 05:46 PM
JDA_BTR JDA_BTR is offline
I found that I was able to get a long squeezer in for two of them and bucked the last one…. it wasn't easy but it is doable. A small tungsten bar is really really helpful.
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
Old 06-16-2014, 06:01 AM
Icarus Icarus is offline
Ditto for the tungsten bar. It is my best friend,
Paul M.
Washington DC
Former Airport Bum
RV-4 / PA28-180
Old 06-16-2014, 09:05 AM
I was able to squeeze them using a 4 inch yoke. There were six holes on the bottom skin/rear spar on the inboard side that were left open per the plans in a previous step. Plus the E-905 rib, front spar and bottom skin were not riveted yet.
I was able to peel the bottom skin back enough to get the yoke in there and squeeze them.
All is good!
Old 03-27-2018, 09:41 PM
iamtheari iamtheari is offline
Digging this thread up because nobody had commented yet that the plans in this step refer to the E-00902-1L “Rear Spar.” The part number is correct, but it is the front spar.
Now, to find some AN470AD3-3.5 rivets...
Old 03-28-2018, 09:37 AM
Noted, and a revision will be made in the future.
Scott McDaniels
Hubbard, Oregon
