Old 03-20-2014, 09:09 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Default Weight and Balance Form - RV-12
Okay guys, you can tell I'm getting close to the end with all these stupid questions of mine. Where are/is the weight and balance form that goes in the permanent record? The only thing I've found is the worksheet in the acceptance procedures, which I've completed. (754 lbs and 79.85 in.) I also found a spot in the operator guide to enter the data but no specific form. Is there one?
Randy Pflanzer
Martinsville, IN (II87)
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 03-20-2014, 09:24 AM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
Check PM - I sent you a link
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2018 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 03-20-2014, 12:00 PM
I think it's one of the Vans site downloads.
Old 03-20-2014, 01:18 PM
Special Delivery's Avatar
Special Delivery Special Delivery is offline
Randy,
Sent ya a PDF (fillable) form we use for Eagle's Nest Projects. Sent to your email pilot@xxxxxxxxxxx
Hope this helps!
R. E. "Ernie" Butcher
Friends of the RV-1/Eagle's Nest Projects
"Mentors build the student...
Students build the airplane." -Glen Salmon
Dedicated to the historical preservation of the RV-1 Aircraft
and organized for the purposes of promoting, supporting,
fostering, and engaging in aviation and aerospace education.
www.RV-1.org
www.EaglesNestProjects.org
Old 03-20-2014, 05:37 PM
f1rocket's Avatar
Thank you so much for the assistance.
Randy Pflanzer
Paid through 2043!
Old 03-24-2014, 10:12 AM
664781 664781 is offline
The FAA also wanted me to fill out a most Fwd C/G calc. and most Aft. calc. for my records. It was a good excersise to see how the RV12 can be loaded.
Used the FAA instead of a DAR this time around.
Kurt Lohmueller A&P
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 03-24-2014, 02:44 PM
DHeal DHeal is offline
FAA Order 8130.2G Airworthiness Certification of Aircraft and Related Products at:
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgOrders.nsf/0/7a09d53fb0d5325586257885004d9e1b/$FILE/8130.2G_CHG1_Incorporated.pdf
is a very useful source for information related to certification inspection of aircraft. For E-LSA aircraft, see: Section 8.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 650+ hours (as of July 2018)!
VAF donation through June 2019.
Old 04-09-2014, 12:13 PM
Buzz J Buzz J is offline
Default Weight and balance forms
Ernie and Kurt,
May I ask you to forward a copy of the forms you sent to Randy? I would certainly appreciate it. I've done the PAP weight and balance worksheet, but not any other form...it does not appear to address rear CG numbers. Am I missing something here? Thanks for the assist/info!!
Buzz
Old 04-10-2014, 05:38 AM
f1rocket's Avatar
I found a great app for my iPhone called "Aviation Weight & Balance". You set it up for your airplane and it does all the calculations for you. It has a lot of neat features.
BTW, I can't get anywhere near the rear CG limit unless I overload the baggage area.
Randy Pflanzer
Paid through 2043!
Old 04-12-2018, 10:54 PM
LUKLA's Avatar
LUKLA LUKLA is offline
Could you please send me that link as well.
Lukla
Glendale AZ
RV-12
Builder # 120706
N316AM Hopefully flying by July 2018
