  #31
Old 04-07-2018, 06:17 PM
bullojm1's Avatar
bullojm1 bullojm1 is offline
I've been meaning to replace my gas struts on my RV-7 tip-up for a couple of months. However, every time I look at Orr & Orr site for the better price ($18.25 each + $8.70 S&H), I couldn't help but think there's got to be something cheaper.
And there is.
I was looking for an alternative to the Stabilus brand version Van's sells. The spec's on the OEM strut van's provides is an extended length of 15.95", stoke length of 6.30", 22.5lb force and 10mm ball sockets on either end. I liked the idea of a strut that had a little more force than the stock one. However, Stabilus only makes a 100N (22.5lb) and 150N (33.7lb) version. Something in the middle would be ideal.
I found the Suspa C16-08941 strut fit the bill almost perfectly. 125N (28.1lb)force, 10mm ball sockets, 6.3" stroke length, and the extended length was 15.7". A little shorter than the Van's ones, but only by 1/4". The best part - Amazon sells them on for $18.25 a PAIR, with free shipping for Prime members (a week ago I paid $14.28, so the price seems to vary).
https://www.amazon.com/gp/product/B0...ilpage_o00_s00
I ordered them last Saturday night, they arrived Monday morning and I snapped them on the RV today. They look identical to the other struts and seem to work just fine. Even though the picture on Amazon shows the struts with an unpainted metal clip on either end, mine came with a black painted clip, just like the Van's ones. The extra force is really nice as it now has the strength to life the canopy up on it's own. The other struts just seem to be able to hold them at whatever place I stopped lifting the canopy. They have an excellent rating, with a 4.7/5 star rating on Amazon, based on 301 votes.
Enjoy the savings!
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 04-07-2018, 06:29 PM
Thanks Mike. Mine have been off and on so many times, I could take them off without much effort on the clip.
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 04-07-2018, 06:37 PM
Brantel's Avatar
Brantel Brantel is offline
Awesome find Mike! You are my frugal hero!
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 04-16-2018, 03:05 AM
AspenFlyer AspenFlyer is offline
Thanks, Mike. These snapped right on with zero issues.
Old 04-16-2018, 06:14 AM
Bill Boyd's Avatar
Default A caution from experience
Don't be surprised if fresh or stronger struts increase the forward force on the closed canopy to the point the sheet metal forward edge catches on the forward fuselage top skin when you try to open it, resulting in a loud pop and a puckered lip and necessitating trimming of your painted sheet metal parts
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 04-16-2018, 08:32 PM
Paul 5r4 Paul 5r4 is offline
Thanks for post Mike. I like to replace the struts at annual in the even numbered years. My vans struts allowed the canopy to drop closed once, (and that was enough for me to learn to NEVER let the struts get worn down). Thankfully no damage. I do like the increased pressure in these so although I've just finished an annual I'm going to order and install these.
Paul Gray
Foley, Alabama
N729PG..... 300+ hrs
RV 7A, Lycoming 0 320 D1A, Sensenich FP propeller
pilotforfun2001@yahoo.com
VAF supporter $$$
Old 04-16-2018, 09:10 PM
newt's Avatar
newt newt is offline
Orr wants to charge $130 to ship to Australia
[ Paid up on 16 Nov 2018 ]
RV-6 VH-SOL
Old 04-16-2018, 09:30 PM
I snapped mine on today - perfect fit and hold the canopy on my 9 up better than original. Thanks for the tip.
rockwoodrv9a
Meridian Idaho
O-320 D2A
Old 04-17-2018, 07:46 AM
bullojm1's Avatar
1 week PIREP - these struts work great! They have enough force to push the canopy fully up once you crack the canopy 30 degrees or so. They also aren't too powerful, as the canopy is still easy to pull down. The 28 LB of force seems to be the sweet spot for what's optimal for a RV tip-up. Time will tell the quality, but for $15 a pair, these are just getting replaced every annual or two.
Mike Bullock
RV-7, Flying!
Old 04-17-2018, 11:02 AM
coming up on annual, I ordered a set. thx for the tip.
