Old 04-15-2018, 03:04 PM
bryannortje bryannortje is offline
Default FS - RV6 Tip Up
I have for sale a very well built RV6 with 0-360 180 HP and CS prop.
Specs as follows:
Build Completed 2002
Airframe Hrs: 655
Lyc. Engine hrs: 655 SMOH
McCauley CS Prop hrs: 415 (original prop changed due to being out of tolerances)
Always Hangared
Hrs could increase with use. Paint: 9/10 Fabric Interior: 8/10
The important stuff - Panel Specs as follows:
Dynon D100 with remote Compass (LH wingtip)
Trio EZ Pilot Autopilot with Alt. Hold (gold servos)
Panel mounted Garmin 495 GPS (to drive Autopilot)
Panel Mount for Ipad Mini with cooling fan
VM1000 Engine management (with red cube fuel flow meter)
PS Engineering PAR100EX Audio Panel and Com 2 (bluetooth and stereo)
Appareo ESG ADS-B out Transponder (built in WAAS GPS)
Com 1 - TQ Avionics KRT2 Dual watch 8.33 Radio (formally Dittel)
E.I. Inc Dual Fuel Gauge (calibrated perfectly)
EXBus electric management - EarthX Lithium Battery (with built in monitor)
FastStack Harness System - adding / removing avionics made easy
2 1/4 " Backup Airspeed / Altitude / Attitude - steam gauges
Electric Flaps
Manual elevator and Aileron Trim
Whelen LED Landing and Taxi lights
LED Nav lights
Standard Strobes
Dual USB Power supply
Canopy Cover / Ultimate Control Surface Gust Lock / Quick drain engine oil drain fitting / magnetic Sump Plug / ASA Oil Separator & Crankcase Vacuum System / Oil Cooler Temp Control / Portable Oxygen System
This aircraft flies straight and the engine runs sweet - never have hot start issues.
Asking $70 000.00
Serious enquiries pls email for photo's and further information / contact.
Bryan
Link to photos: https://www.flickr.com/photos/161051606@N06/
