Old 05-13-2018, 11:14 AM
VF84Sluggo VF84Sluggo is offline
Question RV-3"M"???
Gents,
Been away from RV's for a long while, owned an RV-3 many years ago (148CW, great plane!) Got the itch again, looking at an RV-3M (at least, this is how it's advertised.)
Never heard of an RV-3M. Know about a regular -3, -3A, -3B. The person listed as the seller is not very responsive with an answer. Anyone heard of what makes an RV-3 an "M" variant?
Thanks!
Old 05-13-2018, 05:11 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Nope - never heard of one. Which doesn’t mean someone didnt’ creative with a build. Only the owner is going to help you on this one.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-13-2018, 05:32 PM
Yep, that's what I figure.
Old 05-13-2018, 05:40 PM
az_gila's Avatar
az_gila az_gila is online now
Or a quick search of the FAA registry and VAF
Not positive but this post might be applicable - http://www.vansairforce.com/communit...52&postcount=6
Sounds like a RV-3 originally built with a Subby motor, hence the different designation.
Here are the 3 RV-'s http://registry.faa.gov/aircraftinqu...ltxt=&PageNo=1
And it is also a fastback - http://www.vansairforce.com/communit...7&postcount=12
This is one of them - don't know if it is the from the OP -
This is the Mk I listed by the FAA, not a RV...
Google knows almost everything!!
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-13-2018, 07:59 PM
Thanks for the info. I haven't seen the RV-3 in question in person yet, don't know "N" number (can't see it in the pics.)
The seller's rep has been VERY non-responsive. If this guy was selling MY plane, I'd be a little upset. Two phone calls and two emails have gone un-replied.
Old 05-14-2018, 02:27 AM
arffguy arffguy is offline
I saw an ad for a "RV-3M" on B*******mers. The n-number is visible on the instrument panel. This n-number has also been on a Gulfstream and currently an RV-8 by an inactive VAF member. I wonder when this RV-3 last flew. Possibly Internet database errors, but I have found three n-numbers associated with RV-3's using the same serial number but two different "manufacturers". Hmm?
Mike F
RV-6A wings/fuselage
RV-3 empennage (extra thanks to Mr. Zilik)
RV-4 Plans only S/N 2938
Cessna 152
Elk Grove, CA
VAF #744 Exempt but paid in Feb anyway
Old 05-14-2018, 01:28 PM
Yep, went and looked closer, there's the N-number on the panel. We're looking at the same one, that number currently in the database on an RV-8.
Hmmmm.....
Old 05-14-2018, 03:08 PM
Snowflake's Avatar
Certainly not the plane you're looking for, but This showed up at a local airport this weekend... Marked as a "Meyers 3" and appears to have RV-3/4/6 empennage and wings, with a custom-designed fuselage. I didn't get to talk to the builder/owner/pilot, it left while I was elsewhere on the field. It made a lot of noise climbing out, I figured it must have an O-320 or O-360 in it, and a wood prop.
Rob Prior
