Old 05-06-2018, 05:04 PM
Default F-335 Tunnel Bulkhead Question
I've read that these ought to be set aft slightly to allow for the landing gear.
Can anyone comment about this and perhaps tell me if so, how far?
Thanks!
Skinning my RV-3B fuselage right now
Old 05-06-2018, 05:18 PM
sf3543 sf3543 is offline
Mine is set back 1 from the front of the firewall flange and side skin.
This allows 3/8 clearance behind the gear socket on the motor mount
It could be set back further if you like since the gear leg intersection fairing will cover it.
Steve Formhals
RV6, RV8 (2), RV12 & RV3 99% done.
A&P, Tech Counselor & Flight Advisor
Old 05-06-2018, 06:26 PM
Thanks, Steve!
Old 05-07-2018, 07:34 AM
RussellT RussellT is offline
G'day Dave,
I set mine to the plans(inline with the firewall) and have a little less than 1/4 inch clearance, it doesn't allow a lot of space for the brake lines. My lines run down the back of the gear leg, It is no problem but I will need to ensure no chaffing etc. I also set the end piece of F335 with the flanges inside thinking it might help to avoid collecting gunk in the recess.
Russell
RV 3B. Very slow build. At fwf & wiring..
Old 05-07-2018, 10:34 AM
Thanks Russell, this and Steve's posting together show the situation well.
