Go Back   VAF Forums > Model Specific > RV-3
  #31
Old 03-25-2018, 01:34 AM
CAVU Mark CAVU Mark is offline
Default What happened today
Repair consisted of welding steel bushings on the top of the gear tube after alignment. We welded the bushes on with the gear legs in place.
I installed the repaired gear, this would be the second time I had it welded, the first shot did not meet with my alignment specs. The second was closer but when taxied it shimmied worst than ever. Shook everything inside at a fast taxi. Finished the wood/glass mod today and at fast taxi no shimmy. Yeah! Now for a test flight.
Noteworthy points. I used wood on the front and back of the gear. I did not use "oak" as suggested by my fellow EAA members. I used finger jointed pine trim on the front and solid pine trim on the aft. Didn't think about the finger joints until my contractor friend piped up. Used a mill to bore the groove for the new brake lines.
I did contact Langford and they suggested swapping the gear legs and drilling new holes in the top and the subsequent axle holes. I didn't dig that suggestion and carried on with the weld repair.
My gut said I should not jig in the shop but align it on the plane and tack weld it. I think I will listen to my gut next time since I was expecting it not to shimmy without the wood/glass mod. I am a slightly better fiberglass person now.
New Michelin tires, tubes and balancing took place.
I suppose this gear works well if installed correctly from the start but it is not fun as a repair.
RV-3 restored
Stearman - built - waiting on FAA and DAR
L3 building for San Diego Air and Space Museum
Helio Courier constructing
Old 03-29-2018, 12:38 PM
dacronwall's Avatar
dacronwall dacronwall is offline
Default Gear shmmy
I had similar experience with my gear. The mount was broken when I bought it, and we replaced with the new motor mount and gear legs. I checked the alignment and it was spot-on, but still would get the shimmy unless my landing technique was PERFECT.
SO I put the wood stiffeners on, I did front and back with Maple, and I let in the round with a router, and even put a channel down the leading edge for my brake lines.
All was great after that, but I had a couple of hard landings in gusty conditions and ended up finding the wood had cracked. I ground the glass out and wrapped it again, but I think the wood being partially un-bonded is still causing a periodic shimmy, mostly as I slow (using brakes) after putting the tail down and approaching the runway turn out.
I need to pull the wheel pants and leg fairings off again and see if I can figure out what needs to be done, but that means jacking the plane up and all that fun stuff.
Feel your pain brother....The round gear legs are more susceptible to shimmy than other types, I wish I could say I nail my landing every time, but I don't. Just part of the RV game I guess.
Cheers
Dave Cronwall
N66GB
My RV-3 is more fun on accident than your Cessna is on purpose
Old 04-06-2018, 09:44 PM
Michael Henning Michael Henning is offline
I am not familiar with the landing gear on a -3, but on the -4 the gear is sensitive to tire pressure. Too much or too little, and it will shimmy. I run 32 PSI. Smoky I think mentioned he uses 30 psi. Just a thought. The plans in the -4 manual spell out how to add the wood to the landing gear, but I never needed it.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 04-24-2018, 01:11 AM
Default Shimmy gone but still working on landings
The shimmy is gone when I taxi, I still need to test flight. A few things have gotten in the way.
The jokesters at my EAA chapter have honored me with the Ballad of Mark and his RV-3.
Not sure this will work but here goes.
http://https://drive.google.com/file...ew?usp=sharing
RV-3 restored
Old 04-25-2018, 12:19 AM
Default Maybe this
https://drive.google.com/file/d/0B-M...ew?usp=sharing
RV-3 restored
Old 04-25-2018, 08:12 AM
13brv3's Avatar
13brv3 13brv3 is offline
Are there any other airports you can move to
I still haven't figured out how to consistently land this particular RV-3B. Of course it doesn't help that the runway isn't flat, so you kind of have to play the slope. I'm still waiting to find a hangar closer to home since my current hangar is a 3 hr round trip drive. I've joked that I'm staying here where no one knows me until I figure it out
Rusty
RV-8, SN-80587, built, flown, sold.
RV-3B, SN-10751, rotary engine, built, flown, sold
RV-8, SN-82470, built, flown, sold.
RV-3B, SN-11351, purchased (yes it's cheating)
A&P - 2018 dues paid
