Go Back   VAF Forums > Model Specific > RV-3
Old 01-01-2018, 09:45 PM
jrs14855 jrs14855 is offline
Default Bolt
Originally Posted by DNeufeld View Post
I am not a certified welder so I didn't see that coming. I get it. The problem I see with a plate is there will be a unsupported area between the plate and the gear leg the thickness of the tube. Might not be a big deal??
Not a big deal. The shaped flat doubler is pretty much the standard repair. I think there are a lot more of these repairs than people realize, just not many talking about it. My proposed doubler would be oval on the outside and would be just large enough to extend outside of the peened area. Actually the optimum doubler would be a section of .120 wall tubing cut from a tube with od 1/4" larger than od of socket.
Old 01-01-2018, 10:20 PM
DNeufeld DNeufeld is offline
Actually the optimum doubler would be a section of .120 wall tubing cut from a tube with od 1/4" larger than od of socket.[/quote]
OK then. How about slipping a snug fitting .120 solid tube piece over the top. Leave the new piece about 3/16" above in the rear and slightly below the original tube in front for ease of access to weld. Should be able to weld that without removing the mount?
We can keep this going all night!
Old 01-01-2018, 10:54 PM
Default Weld
There simply is not enough room to do any welding on the aft side of the gear socket. The mount must be removed form the airplane. As I posted before, a talented welder can close up the holes on the 6A main gear.
Who's on first What's on second and I don't know is on third. If you never heard the entire thing this would be an excellent time to look it up. Great stress reliever!!!
Old 01-01-2018, 11:00 PM
Default Who
Abbott and Costello "who's on first" dates to 1938. Audio, video and text available online. One of the all time classics in my opinion.
Old 01-01-2018, 11:07 PM
OK then. How about... How many ways are there to plug a hole?
I've seen it. It's one of my favorites
Sorry CAVU
Old 01-02-2018, 12:23 AM
It is a common repair method but this is a very oversized hole.
That would mean that instead of a single shear point on each end of the bolt it would be in double shear with a slight gap inducing a bending moment.
Less than desirable. I would be looking for a different fix it it were mine.
Scott McDaniels
Hubbard, Oregon
Old 01-14-2018, 10:12 PM
CAVU Mark CAVU Mark is offline
Default Nothing ever goes wrong....
The report is the gear doesn't align properly. I need to get down to the fabricator doing the work and size things up. The plan is to align the gear and place some fabricated spacers in the holes and weld them to the gear tubes. Perhaps the gear is bent from my learning to land on these springs.
P.S. I know people think highly of Van's but I did send a request to them for a repair suggestion and no reply. Thanks to VAF I have some input, making the VAF contribution worthwhile.
RV-3 restored
Stearman - built - waiting on FAA and DAR
L3 building for San Diego Air and Space Museum
Helio Courier constructing
Old 01-14-2018, 10:19 PM
mfleming's Avatar
mfleming mfleming is offline
Just a thought. I always follow up a Van's email with a phone call.
Sometime the email gets lost in the shuffle between the three techs.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated and so should you
Old 01-15-2018, 09:44 AM
Did you follow up after you got no reply?
It is fairly common for breakdowns to happen with e-mail (it is not 100% reliable).
One of the common causes of a failed connection with Van's tech. support is for the reply to go in the customers SPAM folder.
Scott McDaniels
Hubbard, Oregon
Old 01-16-2018, 12:28 AM
Default Repair started
I did not follow up with Van's. I suspect that Van's response would be covered by responses here so I forged ahead.
Today we aligned the gear on the mount which was bolted down to the welding table. A few spacers (3/8 bolt dia) are going to be welded to the mount. A calculated repair considering all the input and that of the fabricator.
I tried to talk him into making the Grove type gear but he wasn't interested. He'd rather build English race bikes.
RV-3 restored
