I connected the echo/sky units yesterday. I waited 3minutes for the WiFi to appear. It never did. How long does the unit take to show up? I did verify power and ground to both connectors. I?m using the navworx cable they sent.
I was waiting for something starting with ping... on both my phone and iPad and it never showed up. I was asking if anyone knows about how long for it to show up.
Should be available to connect up to wifi within 1 min if you have powered up the echo and can see the appropriate indicator led s on the Echo. As stated above, the wifi will be named PING XXXX .
Put one in a RV 7 couple weeks ago that actually had a bad connector and or wire crimp in the black plug and was not powering up unit. May want to check that if you have NO LED indicator lite.
Actually uAvionics swapped the Echo out for me no questions ask and sent me a new one. Plugged it into the OLD ( original plug ) and had same problem . Pulled out the old black plug and installed the new one ( with the replacement unit) and all worked well . I would bet the original echo would work had we just replaced the plug. I didn t do autopsy on the OLD plug but that confirmed for me something not connected internally.
