Old 11-11-2017, 04:11 PM
Wiley Price Wiley Price is offline
Water found in gascolator was clear as spring water. There was no water or debris in carb bowl. Who and how much to overhaul carb?
Old 11-11-2017, 05:09 PM
snopercod's Avatar
Idle mixture needs adjusting? On the ground, I'd try the idle mixture test if that's possible.
(2018 dues paid)
Old 11-11-2017, 05:52 PM
It is not unheard of but it is rare for the idle mixture to just change.
The first order of business would be to inspect to be sure that nothing else happened to make it change.
Carb. float failures are rather common. That is the very first thing (after the other things that have already been done) that i would check.
It doesn't require sending out for overhaul. You just need a new bowl gasket and a set of new screw locking tabs. Any halfway decent mechanic should be able to help you take a look inside.
Scott McDaniels
Hubbard, Oregon
Old 11-11-2017, 05:56 PM
Ben Meyer Ben Meyer is offline
Call Russ at dgsupply.com
Fast turnaround, just do an IRAN. Be sure to tell him it's for an experimental.
Ben Meyer
FFC
RV-6A
Old 11-12-2017, 06:30 AM
Skysailor Skysailor is offline
As long as the cowl is off while you look into the float, check that all intake tubes are secure to the cylinders. An intake leak will also manifest itself most at idle but be tolerated at higher power. Free and easy check.
RV4
Paid through 2018! How about you?
Old 11-12-2017, 07:07 AM
Bob Martin's Avatar
Bob Martin Bob Martin is online now
Default Agree
Plus 1 for this.....
Also, I have read many times about Carb bolts/nuts coming loose and causing a bad intake leak as well.
An intake gasket leak usually causes disturbance in one cylinder and therefore a rough ilde or hot cht......but a complete shutdown would most likely mean something worse. But not ruling anything out, it could be several intakes leaking.
Good Luck
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 11-12-2017, 08:04 AM
RichE7A RichE7A is offline
Default Idle
I had the same thing happen several years ago at a fuel stop during a cross country flight.
Long story short, the idle adjustment screw had departed during flight.
Rich
Old 11-14-2017, 09:45 AM
WingsOnWheels WingsOnWheels is offline
While you are at it, check your primer circuit/fittings (if you have a primer). Make sure the primer isn't flowing when the boost pump is on.
Colin P.
RV-6A #20603:Painting and moving to the airport for final assembly. Getting very close!
PP SEL / A&P
N616CG (Reserved)
I donate every year on my B-Day (in Dec)
Old 11-14-2017, 12:34 PM
i had a sinking float years ago. no problem with stalling at idle but needed to run a leaner mixture in cruise.
TURBO YES =VAF= Payed Jan2018
Old 11-14-2017, 12:56 PM
Depends on how bad it sinks.
I have seen them them fail so bad that fuel was running out of the bottom of the air box if the electric pump was turned on during troubleshooting
A little more specifics....
There are a bunch of different float designs in use.
Some are metal some are plastic coated foam.
Some are molded plastic pieces that are ultrasonically welded together to form a hollow air filled space.
The foam examples will generally just slowly gain some weigh by becoming saturated with fuel.
The metal ones would partially fill with fuel because the seam was at the mid point and it would trap an air bubble above.
The welded plastic ones would just about totally fill with fuel because the seam was near the top of the float.
These were the ones designed and used by Precision. I think it was the chronic failure of these floats that pushed them to sell the carb part of their business.
Scott McDaniels
Hubbard, Oregon
