Old 03-18-2015, 07:07 AM
Gahannaflyer Gahannaflyer is offline
Default Reamer .311
On section 25-02 steps 5, 7, 12, it requires a .311 reamer to make the dimension of the holes just right. but I am struggling to find a .311 reamer to do this. I have a 5/16" (.3125) reamer but I'm uncomfortable making this substitute. Does anyone have any pearls of wisdom on this?
Steve
Old 03-18-2015, 07:24 AM
bret's Avatar
bret bret is offline
Do not use 5/16.....don't ask how I know.......
2019 gladly supported
Old 03-18-2015, 07:39 AM
BillL BillL is offline
Steve
Any machine supply company has reamers in any size you specify. Have you checked with Avery, Cleaveland and others for the .311? Call them.
Avery : http://www.averytools.com/prodinfo.asp?number=15380
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 03-18-2015, 07:54 AM
frazitl's Avatar
frazitl frazitl is offline
Check out post#4 in the thread below. Our club will rent you the tools including a .311 reamer for $25 +shipping (+- 12.50 each way usps priority). Not certain it will work on a 14 but if its the same as a 7 more or less it should fit. Check out pics and call me if interested 702 two seven 8 zero 273.
http://www.vansairforce.com/communit...ad.php?t=57760
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
Old 03-18-2015, 08:28 AM
JDA_BTR JDA_BTR is offline
I just bought mine from Avery
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
Old 03-18-2015, 09:20 AM
flion's Avatar
flion flion is offline
Grainger has them, either straight or spiral flutes. Here's the straight:http://www.grainger.com/product/GRAI...Code=P2IDP2PCP. Technically .3115 but I don't think 5/10,000ths will should bother you.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 03-18-2015, 10:22 AM
Ron B. Ron B. is offline
Actually Van's replied to the other thread mentioned above that we need to use the .311 , not the .3115 reamer. (Corrected this post as not to confuse anyone.)
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 03-18-2015, 12:04 PM
jrs14855 jrs14855 is offline
Default Reamer
mscdirect.com, variety of .3115 reamers ranging from $20 to $90. The cheaper ones are fine for a one time use.
Old 03-18-2015, 12:11 PM
Originally Posted by Ron B. View Post
Actually Van's replied to the other thread mentioned above that we need to use the .3115 , not the .311 reamer.
No, the recommended reamer size is .3110.
Scott McDaniels
Hubbard, Oregon
Old 03-18-2015, 12:19 PM
