Old 02-08-2015, 03:56 PM
ShortSnorter ShortSnorter is offline
Default HS Flange Crack
Only 8 rivets kept the HS from being officially complete.The plans have you wait to rivet the final inboard ribs until you can take the HS out of the cradles and lay them down for better access to rivet. Even with the HS flat on the table the rivets are somewhat awkward to get to. The first rivet I drove was unacceptable and had to be drilled out. After regrouping and retooling with my offset rivet set I started to drive the new rivet. I stopped after getting the rivet partially set to check the progress. The pictures below show what I saw. The point of the bucking bar I was using must have cut right through the adjacent flange while I was riveting. Can the inboard rib be removed and replaced without drilling out the entire side of the HS? My concern is that the the way the rib is nested in the stringer assembly may prevent me from drilling out the affected rib.
Old 02-08-2015, 05:02 PM
Ron B. Ron B. is offline
Certainly no expert, but I would cut that flange off and smooth the edges in place and rivet an angle to the rib duplicating that flange.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 02-08-2015, 05:18 PM
TimO TimO is offline
Ron and I think alike. That's what I'd do too.
Tim
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1375+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 300+ hours http://www.MyRV14.com
RV-10/14 Transition Training: http://www.RVCFI.com
Old 02-08-2015, 05:31 PM
Interesting thoughts guys, that's what makes VAF invaluable. Those single hole flanges are so pesky!!
Old 02-08-2015, 07:06 PM
rv6rick's Avatar
rv6rick rv6rick is offline
JOAT-MON & Moderator
Something to consider:
-spar/web rivets 'appear' to be overdriven, a lot.
-rivet above the rivet/flange you are questioning 'appears' to be under driven and the flange doesn't look like it's fully nested. Address.
-2 rivets up - 'appears' to be set in an oversized or oblong hole. Address.
-flange dimples 'appear' to be less than crisp, a lot.
-if you keep your bucking bar on the rivet you won't scratch the primer off of your parts
Above comments realizing that pics can be deceiving.
Response to your question: many-a-flange has been removed and replaced with a new one.
As experience is gained skill usually improves. Rivet gauges can help in the meantime.
Good luck and have fun. Slow and steady as she goes .
Rick Gray in Ohio - Builder Assist Center - 50+ Awards & counting
Whirlwind Prop Dealer
EAA Oshkosh Homebuilt Judge / EAA Tech Counselor / EAA Flight Advisor / F.A.S.T. Formation Flight Lead
Kitfox Completed
RV4, 6, 7, 8, 9, 10, 12, & 14ís
6 RV10's Finished
F1 Rocket #1 Oshkosh Grand Champion :-)
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
49 RV's & Rockets & counting
http://www.rvrick.com
Love my Pitts S-1S
Old 02-08-2015, 07:38 PM
JHartline JHartline is offline
Default Cracked flange
I had similar difficulties with these rivets. A second set of hands, an offset rivet set, and a piece of rubber tubing around the rivet tails got everything comes cinched up tight. I also put a piece of masking or duct tape around the bucking bar to keep scuffs to a minimum. A helper, in my opinion, is required to get these particular rivets set properly. Best of luck.
James Hartline
Carrollton, GA 5GA2
RV-14 - Hoping to fly sometime this century. Almost done.
T-Bolt IO-390
Maule MX7-180
Old 02-09-2015, 09:00 AM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Default duct tape
Also, you can put small pieces of duct tape your bucking bar to be placed next to primed aluminum...this will prevent the aluminum/primer from being scratched.
Ryan Allen, CFII
RV 7 N612RA
E-170/175
Old 02-09-2015, 12:49 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Radiusing the bucking bar edges and some duct tape will also protect the primer/parts. I had to dress my tungsten bars as the edges were way to sharp. If you need that last 1/16" of the edge of the bar, there is probably something else wrong.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage in progress.
Old 02-09-2015, 01:21 PM
JonJay's Avatar
JonJay JonJay is offline
That bar looks more like a cut off tool than a bucking bar.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-09-2015, 10:03 PM
gladiator68 gladiator68 is offline
Not a -14 guy but a couple observations.
Definitely use a different bucking bar.
Photos are deceiving but check your rivets on the spar. They look a little over driven.
This comes from a guys who has had his share of "redo's". Good luck
Rick Glatthaar
Olympia, WA
RV-9
Tail done, wings done,
Fuselage "almost" complete, working on wiring/panel
Double dues paid for 2018.... Thanks Doug!!
