Old 01-22-2015, 06:41 PM
Ron B. Ron B. is offline
Default Elevator travel
The F-01450 stick stops prevent my elevator from traveling to specs. The elevator horn needs to travel about 3/16" more in both directions. I assume I need to sand/file the F-01450 in order to get this travel back? Are these stops the only stops for the elevator? Hope not, hopefully the horn will be hitting stops also.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 01-22-2015, 07:55 PM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Elevator
Ron,
There is one more set of stops at the aft end of the fuselage. Did you measure the travel while building the tail kit? There is a revision ( maybe Section 36?). That revision goes over filing the stops for the required travel.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 250+
2018 Dues Paid
Old 01-22-2015, 08:26 PM
Maybe that is why I had filed the stops back there to get the proper travel and did not see instructions in my manual. I'll have to look for the sheets to that revision.
Thanks Ron
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 01-22-2015, 08:49 PM
Found the revision, I think I have a little filing to do on the stick stops. I did meet the stick travel angles as is but not the elevator travel ,but the revision has increased those angle so that helps.
Thanks again, short memory.
Thanks Ron
RV-10 SOLD
RV-14 Flying
