Old 01-12-2015, 02:06 PM
ShortSnorter ShortSnorter is offline
Default Forgot to rivet....Now what?
While buttoning up the rudder skins, I must have missed the part about riveting the forward flange of the counter balance rib. The easy answer is to remove the counterweight, secure the skin to the rib and re-install the counterweight. The problem is there are two massive globs of JB weld standing between me and the lock nuts securing the counterweight. Any alternative solutions to securing the two rivets other than removing the counterweight?
Old 01-12-2015, 05:18 PM
You also need to dimple countersink the front side rivet locations....
There really isn't any other alternative other than doing what you already know. Bight the bullet and take it apart.
Scott McDaniels
Hubbard, Oregon
Old 01-12-2015, 05:44 PM
Good catch, you just saved more potential heart ache.
I figured.... Any tips for Jb weld removal?
Thanks for the help!
Old 01-12-2015, 06:30 PM
maniago's Avatar
maniago maniago is offline
So just a thought, if you jb welded the weight in youre not expecting this to ever come apart right? How about shooting some T88 in through the holes and lock it all in place? Itll never ever come out.
Mani
MustangII (FoldingWing) "Finishing up": IO360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,Navworx; SteamAlt,AS,VSI,wet compass
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Jan2019
Old 01-12-2015, 06:34 PM
sblack sblack is offline
Heat will soften the jb weld easily. This is a dead easy fix. A heat gun or one of those butane pencil torches but if you use flame have good ventilation.
Scott Black
Old school simple VFR RV 4, O-320, wood prop, MGL iEfis Lite
VAF dues 2019
Old 01-12-2015, 06:57 PM
The Jb weld is only on the locknuts on top.
I didn't think about the heat gun option. I think I'll give that a shot! Thanks for the tip.
Old 01-12-2015, 07:09 PM
SMO's Avatar
SMO SMO is offline
Not so sure you need to deal with the JB weld. I suspect those bolts will just screw out of the JB weld anyway. Might take a bit of oomph to crack them loose.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
