Old 05-23-2017, 06:54 AM
RV6-KPTW RV6-KPTW is offline
Default Fuel Bracket 31-08
Hi,
I am snapping the middle tongue of these fuel brackets off with very little pressure during installation of the fuel line - 8 so far. That is not the big problem, its drilling out the blind rivets... Has anyone solved this fuel line attachment another way - adel clamp or similar?
Dennis Callaghan (KPTW -> X26/KMLB)
- RV14 sn:140193 - mostly done. Procrastinating on fiberglass
- 2000+ hours on my RV6!
- Dues paid 12/2018 * 2
Old 05-23-2017, 08:13 AM
n982sx n982sx is offline
I had no issues at all. They should work very well.
This may seem obvious but do you have them in upside down?
I assumed that the top opening is meant for an optional return line because it is a smaller diameter than the bottom opening. See page 31-02
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 05-23-2017, 09:30 AM
Ron B. Ron B. is offline
I broke one of mine. I used a corner of my plans binder as the materials were similar to fabricate another. Make sure the bolt holes are large enough as I believe that is what broke mine.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 05-24-2017, 03:00 PM
The fuel brackets are correctly oriented. The fuel line is a snudge short so pressure is being placed on the brackets sideways during installation and they just snap. I could make another line but think that a different type of mount would work just as well. I will continue to explore.
Old 05-25-2017, 06:05 AM
Make another---or ours are bent on a CNC. TS Flightlines and Aircraft Specialty.
Tom
Ridgeland, SC
Old 05-25-2017, 06:52 AM
Tom023 Tom023 is offline
Just a plug for Tom and Steve's prefab lines. Absolute perfect fit, could not have been a spec better. Easy drop in installation and then wrestling with the tiny screws inside the ribs to secure the second half of the clips, but no broken ones.
RV14A #140083
Inspection June 27
2018 Donation+
