I've clamped the spar caps (HS-1013) to the front horizontal stabilizer spar (HS-1002). The spar caps protrude past the flange by a full 1/16" of an inch. This seems a bit unusual, and the VS spar caps did not do this. Are one of these pieces the wrong size? I've checked, and do have the orientation correct with the trimmed side against the spar web. The caps are sitting flush against the web and the flange, nothing appears bent...
