Old 04-20-2018, 03:40 PM
Nihon_Ni's Avatar
Nihon_Ni Nihon_Ni is offline
Default How do I get electrical experience?
In the past few months I've been working hard on learning about electricity so that I can make informed decisions about how to design and implement an electrical system into my RV-8. I've watched all the related Hints for Homebuilders videos, I went to the Sport Air workshop on electricity, I've read Bob's book twice and have done my best to learn from other builders through discussions here and on other forums.
I posted my design a few weeks ago and got a lot of great feedback. However, some of that feedback is troubling to me, and frankly has shaken my confidence in my ability to design and install my own system.
I'm sure electrical work is like any other area of building a plane -- there are some definite right and wrong ways to do things, and lots of ways to accomplish things that are right, and even more ways to accomplish things that are wrong!
I experienced this same sort of conflict when I began metal construction. One builder would recommend one thing, another would say to avoid that and do it another way. At that point in my project, following the plans gave me the experience I needed to form my own opinion with respect to metal work.
My trouble with electrical work is there aren't detailed plans for me to follow to gain experience so that I can form my own opinions. I have no idea if fuses are better than CBs, but that's a decision I have to make up front so I can design my system around that decision. For this particular item, I read Bob's book where he laid out an argument for fuses. I thought about it and agreed with him on it in principle, even though I don't have my own experience. That one was relatively easy, but there are hundreds of similar electrical decisions to be made that aren't so easy.
I don't want to do something because someone said to do it, no matter if he's Bob, a guy on the internet with an opinion, or one of the Wright Brothers. I want to learn why people recommend a certain thing so I can understand the problem and solutions and then be able to pick the one that represents the best option for me.
So my question to those who have gone before, how did you educate yourself well enough to be able to make your own decisions? I was feeling pretty confident in my abilities to design and install my system, but now I'm not sure.
Grateful for any insight you could offer.
Rob
Rob K
真喜志友幸
RV-8 under construction as of Sep 30, 2012
Tail kit completed on Feb 8, 2012 (180 hrs)
Wing kit mostly completed, fuselage under construction as of March 6, 2014 (750 hrs)
Paid up for 2018
Old 04-20-2018, 05:30 PM
RV6_flyer's Avatar
I don't want to do something because someone said to do it, no matter if he's Bob, a guy on the internet with an opinion, or one of the Wright Brothers. I want to learn why people recommend a certain thing so I can understand the problem and solutions and then be able to pick the one that represents the best option one for me.
Rob
Rob:
You are asking the right questions on for the decisions that you will need to make.
Asking on the Internet, you will get lots of opinions for FREE. Since you paid nothing for them, some of them will be worth nothing.
It has been my experience to divide and conquer. Break the decision down to as small of parts as you can. List the Pros and Cons.
You are correct in that you must make the decision. Gain as much info as you can on the subject and reason it out.
I wanted to learn more about electricity when I was young. I went to College and got a degree in Electrical Engineering. I got a Ham Radio license, I built kit built electronics, I helped wire a house, I had a job repairing electronics, I had a job building interface cables, etc. Yes there is a lot of learning by doing AND making mistakes. We do not like to make mistakes with our airplanes.
I am not saying you should do everything I did to get experience but you can see that I am one person that learns by doing. Yes I have done things that I did not like, ripped it out out, and did it all over. That is part of the learning experience. It costs money and time. We homebuilt aircraft builders have time and most of us do not have a lot of money.
Here is an example of using pros and cons for one of your electrical questions.
Do I use Fuse or Circuit Breaker?
1st, what is the purpose of the fuse or circuit breaker (CB)?
The purpose is to protect the wire.
Pro and Con
Fuse Pro
Light Weight
Inexpensive
Fuse Con
Requires switch
Must have replacement when it blows
May not be replaceable in fight
CB Pro
Easy to reset / reusable in flight
CB Switch eliminates switch and one piece of wire (2 connections)
CB Con
Heavier than fuse
More Expensive
Can cause distraction while flying when necessary to reset
Unfortunately there are a lot of decisions like this that must be made. EVERY choice is a compromise.
I designed my aircraft electrical system while I was working a job in Japan. That was in the mid 90's. Airplane made first fight in 1997.
With my background, my own ideas and design were very similar to Bob Nuckolls. There were a few things I did that Bob did not recommend but there were things I wanted.
IF you can find someone that is doing electrical work, ask if them if you can look over their shoulder and help them. If you are like me, you will learn from watching and doing. If you were close to me, you could watch the questions I am asking myself about the installation of APRS Transmitter in my aircraft, location of APRS antenna, can I use one G5 RS232 for my APRS GPS source and my second G5 RS232 as serial altitude encoder data to a future ADS-B Transponder? What Wire size? What fuse size? What way will I route my wire?
The way the wire is routed in the electrical system can be important. My old steam gauge panel with compass mounted in the panel, had to have electrical wire kept away from the compass as electrical current creates an electrical field that will cause errors in the compass. After the installation of the two G5s and GMU11, the compass is redundant and no longer necessary but back in 1997 when the aircraft first flew, I did not want compass errors caused by my electrical system.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 04-20-2018, 06:04 PM
Mich48041 Mich48041 is offline
Rob, do not be discouraged. Your latest schematic is looking pretty good. Just a few more minor changes and it will look exactly like Bob N's. Seriously though, you will not go wrong by using Bob's Z-13/8. Many have tried to improve upon his architecture, but few have succeeded. Keep it simple and there will be less to go wrong. There is more than one way to skin a cat. Sometimes it is not a matter of the right way or the wrong way, just different ways, either of which is acceptable. Fuses versus circuit breakers is one example. It is a matter of personal preference. Being able to reset a circuit breaker in flight is not an advantage. It is a disadvantage because the pilot might be tempted to reset it, which could result in a fire. Wait until safely on the ground before troubleshooting an electrical problem. There should not be any device that is critical to safe flight. For each device, ask yourself what the backup plan is if this device fails.
To answer your question, the way to get electrical experience is by making mistakes.
Joe Gores
RV-12 Flying
Old 04-20-2018, 07:51 PM
catmandu's Avatar
catmandu catmandu is offline
Educate. Design. Decide. Install.
Lots of verbs there, and, IMHO, the right ones, except for one:
Educate, design, critique, decide, install.
Remember, you are not just the work force here, you are the project manager. You need to move a bit toward the management side for a bit.
So, as a worker, you gained an education in electrical systems, you designed one based on that education, and you asked for critique.
Now, as a manager, you need to draw upon your earlier education, supplement it with some more, evaluate the critique given, and decide. There is no perfect decision, but there is a best one, right now, given all you know. You can live with that decision. Really, you can.
Then you transition back to being a worker, and start to install. And when the worker finds something the manager missed, you start the process all over again, albeit on a much smaller scale.
Just wait for the fun that awaits you in post-production field modifications!
And as I re-read what the others have replied, all I really am doing is piling on, so much for being a sage. Still gonna post, though.
Mike C.
Maryland's Eastern Shore
stuck in 1/5th of an Arrow, my partners won't let me go
RV-6A bought flying
Old 04-20-2018, 08:33 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Hi Rob. My learning curve was pretty steep too. I can’t provide a recommendation for a source of learning but perhaps a philosophy might help you decide how much you need to know.
A comment another builder made to me that in retrospect was very prescient was to ignore the overly complex electrical systems many other builders use that just aren’t necessary for the vast majority of (especially VFR) RVs. In fact it is MUCH better to design and use a simple design that you FULLY understand than a more complex one that you do not. In an emergency a lot may ride on your full understanding.
FWIW, I followed a combination of Vans electrical design and bob nuckolls most simple design. Going simple made the learning curve much less steep. By the time I installed their designs I knew a far greater bit about electricity than I understood before starting.
Hope this helps just a bit.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2019
Old 04-20-2018, 08:35 PM
terrye terrye is offline
You have done all the right things and studied the right sources to gain the knowledge you didn't have before. It sounds like you don't have a lot of piloting experience (not a criticism, I don't have very much either, and it's almost all in my Cessna 150 with a very basic panel). So to further fill in the gaps in my knowledge, I was fortunate in getting a great tutorial from Gary (since retired) at Aerotronics and having a flight instructor who is a former airline pilot. I'd suggest Aerotronics, SteinAir or a similar company for you to deal with and also perhaps find an instructor with airline experience.
Terry Edwards
RV-9A (Fuselage)
2018/2019 VAF Contribution Sent
Old 04-21-2018, 01:32 AM
RandyAB RandyAB is offline
I'm at the same stage you are at and have felt the same feelings of despair. I think that designing your own system is imperative to understanding what to do if failures pop up but it's a bit of a leap to get from a zero knowledge state to putting something on paper. What I've found tremendously helpful is to look at what other builders have done. Many are forthcoming with their schematics if you ask, while others protect their designs like it was the secret Coke formula. By looking at other's ideas in addition to Bob's Z-diagrams and Ausman's book, you see commonalities that consolidate standard practices and lead to greater understanding. You also get to see different solutions to the same problem which gives a larger repertoire to choose from when designing your own.
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
Old 04-21-2018, 07:04 AM
Mark Dickens's Avatar
Rob,
To me, there are two learning "experiences" in wiring your plane: 1. the design, in which you have immersed yourself. 2. The mechanical implementation of your design. Of all the sources you quoted for information, if I had to choose one and just go with it, it would be Bob Nuckolls. He does a great job of addressing both areas. You can't go wrong by just implementing one of his designs!
Wiring a plane is like writing software. Lots and lots of ways to accomplish a single goal. I went with the VPX, and am happy with it, but I also use some fuses for my battery bus. CBs are a proven and reliable alternative. That's why certified planes have them. All are good alternatives. Pick one or a mix and get on with it. Your goal here is to build a plane, not an electrical system. Have your watched SteinAir's videos on Youtube? Great stuff there!
While I haven't been through your scheme like others have, it sure looks complicated. The more complicated the design, the more wire, the more frustration, etc. Why not take a clean sheet of paper and see how simple you can make it this time? I mean bare bones. I'll bet it looks like one of Bob's diagrams when you finish! These are little homebuilt planes, not airliners, and you can't fly them the same way in the same conditions. Every once in a while, when there's weather across the country, I'll go out to flightaware.com and search for RVs...rarely do I see anyone on a trip, and there's a good reason. They are not great planes for IMC, especially long stretches in the clouds or in turbulence, rain, etc. The plane's wiring, avionics as well as how you fly the plane need to reflect that reality.
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight 11/20/2016
www.marksrv8.com
Old 04-21-2018, 10:22 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by Mark Dickens View Post
Rob,
I pretty much agree with everything Mark wrote here, and would only add a couple of thoughts. First - Bob Nuckollís isnít just another homebuilder. He is a professional GA aircraft electrical systems designer who does this for major names in teh the certified airplane world. They bet their liability and business future on his work, so he has to meet pretty high standards. And his designs(and lifetime of experience) are there for you to use. SOmethign to think about!
Second, you get practical experince the same way we all do - by trying stuff, making mistakes, doing better the next time, and eventually reaching a level of competence. Practice making crimps and testing them. Practice lacing bundles. Practic running wires and be prepared to redo them. Donít expect shortcuts to help you.
Simple is better, as simple as possible (but no simpler) is best.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-21-2018, 11:41 AM
DanH's Avatar
DanH DanH is offline
I don't want to do something because someone said to do it.... I want to learn why people recommend a certain thing ...
Keep asking why, and you'll do fine.
An observation:
Builders select an airplane kit because most don't feel confident in their ability to design their own, or build from scratch. Even pro structural and aero engineers buy kits, because the end result, in their professional judgment, is as good as anything they could design.
Most builders buy an engine, because they don't feel confident about building up their own, be it Lycoming, Subaru, or other.
A high percentage buy a complete plug and play panel, same reasons.
So why is it that so many feel they must jump in the deep end and design a world-beater electrical system, when it's possible to wire 90% of the RV's straight from a Nuckolls diagram, with no variations at all?
It's not a criticism Rob. I'll suggest you're demonstrating good judgement by questioning your design and ability.
True story. When I was five, I asked my grandfather, a career bridgeman, "Grandpa, why aren't you scared of heights?" He looked down at me, and said "Son, I am scared of heights. That's what keeps me alive".
+2
Dan Horton
RV-8 SS
Barrett IO-390
