Low n Slow
About 2 hours ago, we were just about to cut into our fuselage to install a NACA duct just below the cowl cheek like we?ve seen on dozens of other RV-4?s, when our mechanic came up with a new idea.
He suggested mounting it on the avionics access panel between the upper engine cowl and canopy. It seems to us the advantages far outweigh the disadvantages, but because we?ve never seen one there, we thought we might be overlooking some obvious problem that someone here might be able to point out.
Advantages;
1. The biggest advantage I see is no interference with our feet and the scat ducting.
2. Once in the fuselage, it?s there for good, but if it?s on the panel, we could remove or relocate it, as a new panel would be relatively easy to fabricate.
3. Possibly more air flow due to an almost straight run from the NACA duct to the eyeball vent on the lower right side of the instrument panel as opposed to having 2 90 degrees turns if it?s mounted on the fuselage.
Disadvantages;
1. Water is more likely to enter the duct on the rare occasions when it?s raining and outside on a ramp, but if we mount in on the lower rear side, it will only be off vertical by approx 20-30 degrees and our canopy cover would cover the opening.
2. Having to remove the tubing from the NACA duct every time we pull the panel.
3. What are we overlooking?
Advantages;
Disadvantages;
