OK I am stumped
avi8tor50 said:
Actually, I have seen several builders who use a current limiter between the alternator and the main bus. B&C sells them and my understanding is that Bob Nuckolls is leaning more to the current limiter than a large fuse between the alternator and the main bus. The current limiters that B&C sell come in several different amp strengths. Was just wondering what others have used. You might want to check out his site.
Have no idea, never heard of a Current Limiter between the alt and the buss, but than you answered you question, you need one?
I think you are talking about a big FUSE? That fuse is sized at or slightly above the max output potential of the alternator. So you have a 45 amp alternator, 50 or 60 amp fuse will work. Again current limiter? I think fuse.
If not, you are talking about a OV relay.
I would not recommend that on ANY ND alternator. Van does not recommend or warranty alternators with OV relays, but again check the archives and search on OV or over voltage or overvoltage.
I know Bob Nuckolls swears by his OV relay, but
it has been the death of many ND alternators. The fact is ND alternators are very reliable and DON'T go super nova OV like Bob scares people into thinking. The cure is worse than the ill. In fact an OV relay is heavy and adds more connections and chance for failure. Trust me or not, call Van. Bob N's answer is Van is ignorant and Bob. Of course Bob said that before he knew all the problems Van has seen with builders who follow his wiring, specifically the OV relay. Van also sells 10 alternators or more a month for a decade or more; do the math, they hear about all the problems and the common thread in many was Bobs OV relay and "crow bar".
My OV opinion is for most folks no additional OV protection is needed on the ND (NipponDenso) alternators with internal voltage regulation (I-VR). They are somewhat self protected or fail in a safe or benign way. There is the "Plane Power" brand of alternator, which is a modified ND with an extra OV module or protection device. It senses an OV and turns the alternator off automatically. The few people that have experienced OV, with a I-VR ND alternator have found it to be mild. Mild means target voltage should be 14.3-14.6 volts, and the voltage wonders up to 15 or 16 volts. In general you can manually turn the alternator off your self in that unlikely event. 16 volts should not damage modern avionics which are designed to work from 10-30 volts, and tolerate a 60 volt Spike. Of course you don't want to fly around for a long time with +15 volts as it will damage the battery. However as you know if you voltage is high you can usually get it down by lowering RPM and adding more load, like landing lights.
Good luck
