Old 06-07-2018, 09:56 PM
raabs raabs is offline
Default Climate Control
Ed Kranz documented an interesting setup for controlling cabin heat via an Arduino controller. In his setup he uses RC servos to control butterfly valves. I was wondering if any knew (maybe Ed himself?) how the setup worked out.
Did the servos get mounted in the tunnel in the final setup and have they survived the heat?
Have the two firewall mounted servos survived the environment?
Thanks!
Rob Kelly
FL
Old 06-11-2018, 02:46 PM
BGS's Avatar
BGS BGS is offline
Not sure about Ed's setup and it holding up. Assume he has no problems.
I have used these without any issues on all the heat valves, oil and heat selector valves in the tunnel for right left heat adjustments.
http://www.tcwtech.com/control_valve_servo_kit.html
Brian Steeves
#40955 RV-10 - N413BS - Sold
It is Airworthy and Flying. But are they ever done?
First Flight 9/28/2013
#41714 RV-10 - N272BS
Phase 1 Finished, Getting Painted
#120849 RV-12 - N112AB
Flying. First flight Nov 26, 2017
Challenger II - N272MP - Sold
First Flight in 2011
www.briansrv10.com
Old 06-11-2018, 05:37 PM
Weasel's Avatar
Weasel Weasel is offline
I have 2 "RC servos" mounted in the tunnel controlling the heat. So far they have over 1400 hrs on them. I may have had to change one of them but I don't think it was from heat. However my controller only powers the servo when adjusting the position so most of the time they are off.
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1500hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 06-11-2018, 08:56 PM
Paddy's Avatar
Paddy Paddy is online now
Default Heater Control
Like Weasel, I also used R/C servos to control the heater valves. Concerned about the heat in the engine bay, I wanted to keep them on the cabin side of the firewall, so they're attached to Bowden cables routed as per the plans. Works OK but in hindsight, I think the Firghelli linear servos like those from TCW are a better design, are probably lighter and seem to have proven reliable in the firewall forward environment. As an aside, I've never experienced any unwanted heat inside the tunnel. I believe this may be the result of the stainless heater valves being held tightly closed by a little residual tension when the servo is turned off.
The servos in the pictures above were changed out for high torque versions before final assembly, those old ones didn't have enough grunt to reliably manage the friction in the Bowden cables.
Flying as of 10/30/16 after 8 yrs building
Old 06-11-2018, 09:05 PM
Thanks guys! I have been playing around with the servos and think ill take a look at the actuators also.
What controllers are you all using, particularly one that shuts power off except when positioning them? Is it just a standard 10k pot?
Thanks!
Rob Kelly
FL
Old 06-11-2018, 09:47 PM
Paddy's Avatar
Default Servo Drivers
An R/C servo is driven by a PWM signal. A pot by itself won't work. I used servo controllers from Perihelion Design. They're nice and small and include trim for endpoint and sweep, as well as an "off" detent, which I think is important. They're $50 each.
Old 06-11-2018, 10:15 PM
Default servos
I decided to go with the Actuonix (firgelli) linear actuators. They are available in a multitude of lengths, and gear ratios. Also, there are different ways to control them.
As was posted, servos use PWM and require a specific controller. There are linear actuators available that are servo replacements. They also have a Linear Actuator Control board available. It is a really nice board and allows many adjustments. Buy it with the actuator and get a discount.
I also used one for my electric rudder trim...and it has a BUILT IN position sensor...
Highly recommended!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 06-11-2018, 10:37 PM
1001001's Avatar
1001001 1001001 is offline
Highly recommended!
Any chance you could provide the model numbers of the ones you're using? I'm interested in the rudder trim application; I have a trim tab servo that needs to go in the rudder but it it big and heavy. I'd love to find something smaller, lighter, and with position feedback!
And are you using them under the cowl or just in the cabin environment?
Old 06-12-2018, 08:10 AM
Default servos
I am using them on the heat valves, oil cooler butterfly, and rudder trim.
I looked at the TCW oil cooler butterfly valve and played with it at OSH a couple of years ago. I decided to do something similar. They are using their actuator FWF and so am I. I am also using the actuators for the heat valves FWF.
The rudder trim is based on the spring bias system that Aerosport sells. I replaced the drum-and-cable manual knob with an actuator and bell crank.
The rudder trim actuator with position was this one. I also purchased the LAC board at the same time. Very easy to control with a potentiometer and position indicator wiring is a breeze.
https://s3.amazonaws.com/actuonix/Ac...+Datasheet.pdf
The heat valve actuators I used do not have position, and they are set up to act like regular PWM servos. If I did it again, I would just use the LAC board for each actuator instead of messing around with trying to control a PWM servo. The LAC board makes the 12v actuators basically plug and play with a potentiometer, switch, or button...
For the rudder trim, I was concerned about back driving the actuator. I went with the 256:1 ratio. I think it would work with a lower ratio, and be a bit faster.
Bob
290 HP Barrett Hung
Wiring...
