Old 06-06-2018, 07:59 AM
carolsyracuse carolsyracuse is offline
Default Electric rudder trim
http://www.myrv10.com/N104CD/upgrade...104/index.html
Old 06-06-2018, 08:10 AM
Carl Froehlich's Avatar
Originally Posted by mciaglia View Post
I’m confused by this set up. The tab is pronounced on the right side of the rudder, which in turn would cause a left rudder deflection as a result making most trim situations worse.
My Christen eagle and most aerobatic planes have a small
Tab on the left side of the rudder to offset the right rudder needed
To stay in trim. Am I missing something in this setup?
Put the tab on whatever side of the rudder you want. For the RV-10 the ball was just touching the left side line in cruise (as in a little left rudder needed). Other planes will be different.
Note - do not add a rudder trim tab until after very carefully rigging the plane, including the wheel pants and gear leg faiinrg. If these are off just a little, you can get half a ball out on either side. Do not think “once and done” on rigging. This can be a multi-month process.
Old 06-06-2018, 08:50 PM
Paddy's Avatar
Paddy Paddy is offline
Default Pictures fixed
I fixed the missing photos in post #15 if anyone's interested in seeing a version of an electrically operated spring bias design.
Flying as of 10/30/16 after 8 yrs building
Old 06-06-2018, 09:15 PM
CubedRoot's Avatar
CubedRoot CubedRoot is offline
Originally Posted by Paddy View Post
Here's how I built my electric driven spring bias rudder trim. Works well.
Nice Work!! I like this....I'm gonna have to ask for some details :-) so I can duplicate this in my RV-7.
Lynn Dixon
RV-7 Slider -
Tail kit Completed - March 2017
Wing Kit Started - June 2017
My Build Log: http://www.theskunkwerx.com
VAF Donation paid for 2017
Old 06-06-2018, 09:39 PM
Default Or...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 06-07-2018, 08:47 AM
Redline5.9 Redline5.9 is offline
Wow, that is a really clean setup. I like the fact that a guy doesn't have to cut pieces out of the rudder and run extra wiring to the back. What type of servo are you running for it?
Brent Ryz
RV-10 Empennage Build in progress
2017 Dues Paid
Old 06-07-2018, 09:14 AM
Paddy's Avatar
Default Rudder Trim Details
The servo used in my setup is a standard Ray Allen unit, T3-12A if I recall, the one with the long throw. The pulley in front was turned out of a piece of 6061 rod and runs on a bronze bushing captured by an AN-4 bolt through the center. The idler arm is a length of 6061 C channel and also runs on a bushing. There's a piece of 1/16" angle riveted to the underside of the tunnel between the pulley and the arm for stiffness. I bought the springs and arms from Geoff at Aerosport. The mechanism works well, I do use it in flight, especially on long climbs and descents. I like that the spring tension keeps the rudder from flopping around so much in the breeze at fuel stops, although I wouldn't walk away from the plane without the control lock installed.
