Old 06-04-2018, 08:48 AM
lr172 lr172 is offline
Default Question about Seat Belt Attach in Top
I don't have the plans for my finishing kit yet and would like to drill the holes (at least initial pilot holes) in the cabin top while I am filling / smoothing the interior surface. Once I smooth it over, I won't be able to see the solid resin area. I couldn't find a reference in the cabin top section of my manual. Is the hole simply drilled in the center of the round solid resin areas of the top or are there special measurements for these?
N64LR
RV-10 in progress
Old 06-04-2018, 09:08 AM
The plans call for a 5/16 hole centered on the hard point. Nothing special.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 06-04-2018, 09:22 AM
Default hard points
Yes, just center on the hard points. Shine a light behind one side of the cabin top and you will see it pretty clearly...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 06-04-2018, 09:36 AM
Thanks for the guidance. On my green top, the solid resin area is very obvious and has a significant depression surrounding it, hence the desire to fill it.
N64LR
RV-10 in progress
