Old 06-01-2018, 05:15 AM
MConner MConner is offline
Default Instrment panel depth issues
I am installing more avionics and the support structure for the center steel rollover bar is limiting the depth. Has anyone modified that structure to make the top of the radio stack deeper?
Old 06-01-2018, 07:56 AM
rvanstory's Avatar
rvanstory rvanstory is offline
I had to modify the right bracket to accommodate the radio stack angle for the Aerosport panel I'm using. Cut the bracket and back plate, support both with angle. Here's some pics. Hope this is helpful.
Randy Vanstory
Building RV10
N783V - Reserved
Flying Mooney M20J
Emp Kit Completed, Tail Cone Attached, QB Wings delivered and starting Fiberglass Top.
Dues Happily Paid 2019
Old 06-01-2018, 08:02 AM
Electrogunner Electrogunner is offline
Default Center support
How much do you need to remove?
Donation Made For 2017
RV10 N620RV
IO540 C4B5
Whirlwind 375RV
Garmin G900X
Final assembly
Old 06-01-2018, 03:23 PM
Ok further investigation and the clearance issue was the center gusset that supports the panel, nothing to do with the center post. We nibbled about 5 back on a line parallel to the glare shield then down to the bottom of the gusset. Still seems very strong, and there are two other supports for the panel/glareshield to help support.
Problem solved
