Old 05-27-2018, 11:58 AM
MConner MConner is offline
Default Removable ballast
I spend most of the time flying with one or two folks and little baggage. The CG is always just barely at the forward limit.
I know some folks toss in unsecured shot bags in the baggage compartment but that could seriously injure someone if there was a sudden deceleration. I considered a much smaller weight that mounts as far back as possible but was easily removable when the mission called for four seats and bags.
I am wondering if the tail tie down boltís nutplate and structure would be strong enough for around 5# of conformal weight.
Old 05-27-2018, 12:13 PM
togaflyer togaflyer is offline
A liter of water is 2.2 pounds. Carry a couple bottles of drinking water in the back.
Old 05-27-2018, 12:52 PM
Yes many sailplanes have a water tank in the tail for CG control. Not a bad idea but still needs to be secured and at the tail.
Old 05-27-2018, 01:24 PM
Mousse Mousse is offline
I just bought a Swiss Army water bag for this purpose. Its holds up to 20 litres and is made of strong rubber with two handles that can be easily fastened. Available from Army surplus stores for $18.
Michel
Exempted but dues paid through 12/2019
RV-9 Sold
RV-10 Flying
Old 05-27-2018, 02:18 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Similar profile !
I fly mostly solo so plan to make a tail wheel spring weight to put my RV at most rearwardACRO limit for solo flying. It will come off with one bolt for dual flight....FWIW
Larry DeCamp
RV-3B flying w/ carb & Pmags
RV-4 fastback w/ Superior EXP 0360 /AFP & CPI
Clinton, IN
Old 05-27-2018, 02:46 PM
Be careful. That could drastically change the aircraft's spin and recovery characteristics.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 05-27-2018, 03:22 PM
plehrke's Avatar
plehrke plehrke is offline
And make sure you remove when carrying load with aft CG.
Philip
RV-6A - 12 years over 850 hours
Cessna 140 - 68 years over 3400 hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 05-27-2018, 03:42 PM
rv7charlie rv7charlie is online now
And report back after your 1st long solo cross country...
Old 05-27-2018, 04:47 PM
Michel
How and where will you secure your water ballast bag?
Old 05-27-2018, 04:53 PM
Kyle, caution noted. I am not planning to load the plane outside the normal CG limit but right now it is at or ahead of the forward limit with no baggage/ballast.
