Old 06-13-2018, 01:19 PM
Bill Boyd's Avatar
Default Alternative oil cooler
Any reason not to get this from Chief?
http://www.chiefaircraft.com/aec-8000215.html
Looks to be same size as stock, claimed 2 oz lighter and leaves wallet $70 heavier than the Van's part.
Just researching options. I know many went with oversize coolers but others didn't and have no issues...
Appreciate feedback.
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 10-25-2018, 05:17 AM
supik supik is offline
Originally Posted by rocketman1988 View Post
Also:
I would also suggest ADDING the following to save on additional shipping costs:
Engine Baffle Kit
VA-187 4" Duct Flange DO NOT FORGET THIS PART, IT IS NOT INCLUDED WITH THE BAFFLE KIT
VA-186 Oil Cooler Mount
Engine Bolt Kit
Dynafocal rubber mounts
Aren't these parts included in the Firewall Forward Kit?
Igor
RV-10 in progress
Build Log
Old 10-25-2018, 08:11 AM
Default Idk
I did not purchase the fwf kit.
That flange is NOT included in the baffle kit, though.
It is, however, the first step in the baffle instructions!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 10-28-2018, 04:10 AM
Thanks for the note!
Igor
RV-10 in progress
Build Log
Old 10-28-2018, 10:06 AM
lr172 lr172 is online now
None I could find. I planned to purchase this cooler before finding one used for 5 hours. I spoke to pacific coolers, who make that unit, and they claim it is compatible and better, in their opinion, than the niagra.
I am rolling the dice on the 13 row being adequate. I fabricated a turning vane (copied from a production add on) to help turn the air into the upper portion of the cooler. The cooler mount is a poor design that will leave a good portion of the air in turbulence at the bottom choke point and starve the upper half of the cooler. It is my speculation this is the reason that many suffer from high oil temps with the 13 row.
N64LR
RV-10 in progress
Old 10-28-2018, 10:15 AM
woxofswa woxofswa is offline
I put the upsized 07 cooler on a slightly modified stock mount and have never had high oil temp issues in Arizona. In fact, after a couple of winters I had to install a butterfly baffle just to be able to keep the oil temp in the green in cruise.
Myron Nelson
Mesa, AZ
N24EV
RV-10 BPE, Dynon, Airflow systems A/C
First flight May 10, 2014
Old 10-29-2018, 02:28 PM
ppilotmike's Avatar
Myron,
Can you point me to where I can investigate an upsized cooler. Model numbers, etc. would help, as would some more description of your mods to the stock mount. Thanks in advance.
Mike Rettig
EAA Chapter 301 www.eaa301.org
VAF Dues Current: Paid for 2019 on 12/03/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/users/index....ig&project=803
https://www.youtube.com/watch?v=zKCyX2FXrlw
Old 10-29-2018, 02:57 PM
Default Airflow Systems 20007X
I used the 20007X...only minor mods required to install on the stock mount.
Here is the Data sheet:
https://www.airflow-systems.com/wp-c...s-Drawings.pdf
Bob
290 HP Barrett Hung
Wiring...
Old 10-29-2018, 03:00 PM
Sure. I got the plus sized oil cooler here. Specifically the 2007x
https://www.airflow-systems.com/cate...t-oil-coolers/
The upsized one is slightly taller than the standard. The bracket is easily modified by removing some of the faceplate at the top where the regular size nut plates go to make the opening larger to take full advantage of the larger surface area of the cooler itself, and then affixing a piece of angle stock on top to position the new nut plates.
Hard to explain but it should become immediately evident to you when you mate the two together.
I can send pix in a couple of days if needed.
Myron Nelson
Mesa, AZ
N24EV
Old 10-29-2018, 03:11 PM
Dustyone Dustyone is offline
Default Air Flow Systems Oil Cooler
Hi Mike,
The oil cooler Myron is referring to is from Air Flow Systems,the same people who make the Air-Con for the RV-10 etc.
The 2007X fits with only minor mods to the stock oil cooler mount.The instructions that come with it explain all.
Iíll post some photos when I get home .
Ashley Miller
RV-10 #40597
Dual SDS CPI
http://www.vansairforce.com/communit...d.php?t=140051
Airflow Systems Air-Con
http://www.vansairforce.com/communit...4&postcount=15
VH-XTE 500hrs +
Redcliffe,Brisbane
Australia
Photos : https://goo.gl/photos/zsfBeVofHMe4ze7i7
