jsharkey
The Parker B2DX62 solenoid valve used for the Van's primer system has two ports stamped 1 and 2 respectively. I assume that one is the inlet and the other is the outlet. Can anyone confirm which is which?
Thanks in advance.
Jim Sharkey
RV6 O360-A1A FP Tip-up
The A/C Spruce catalogue has the same part and says Port #1 OUT and Port #2 IN - can anyone confirm?
Thanks in advance.
Jim Sharkey
