Old 06-27-2011, 06:43 AM
floridawing floridawing is offline
Default Garmin 496 vs Aera 500 series
I am looking at a used 496 vs buying a new Aera 560. The only reason I was thinking about buying the 496 is that I have read the 496 is much easier to read in sunlight? I hate to buy used with no warranty. Any thoughts would be appreciated. Thanks!
Old 06-27-2011, 06:55 AM
n180tf n180tf is offline
Buy the 560. I also debated long before deciding. It was more about the fact that the 496 operated just like the 196 I have had for years and like. After borrowing and flying a 496 on a couple trips, I decided that the 560 was the better way to go. I am very pleased with the 560.
Tom F.
8TN4
RV-3 Project
Old 06-27-2011, 07:07 AM
Brantel's Avatar
Brantel Brantel is offline
The X96 series is a little easier to read in the bright light but not drastically more so. Borrow both from someone and compare to help yourself make a decision.
Trouble with asking on here is that people will recommend whatever they have since they obviously made the best decision....
The reason I went with the Aera was:
#1. I did not want to invest in older already obsolete technology
#2. I did not want to invest in a device that has a flawed backup battery design.
#3. I wanted to upgrade my 296 to something that had weather capability.
#4. At the time, used 496's were going for around the same price as a new Aera with weather.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 06-27-2011, 09:05 AM
rocketbob's Avatar
rocketbob rocketbob is offline
A couple of months ago I bought a second refurbed 396 to go in my rocket panel. I opted not to go with the 560 since it is not possible to set up the main screen with two columns of data on the right as it is with the 396/496, which is the way I prefer. Judging by the prices of 396's and 496's on eBay it appears the demand for these units is quite high.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 06-27-2011, 02:18 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
I have both. The 496 is panel mounted and the 560 is on an adjustable
mount. They both have features i like better than the other. But I agree
with Brantel, I think the 560 is the better choice. The brightness issue
compared to the 496 is real, but easily managed if you can tilt the screen
in the mount. The 560 is much more compact in size and its mounting system
makes it much easier to manage the power, audio and XM cords. Also, the internal
antenna is very good and the 560 is a great auto GPS.
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 10-07-2015, 01:00 AM
buj94565 buj94565 is offline
will the 560 drive the autopilot the way the 496 does?
Old 10-07-2015, 04:56 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello buj,
Yes, the Aera 560 has an NMEA output like the 496 to drive an autopilot.
Also, one of the most important reasons to choose a 560 over a 496 is the GDL39 ADS-B traffic and weather support. The free ADS-B traffic and weather support on the Aera 5XX unit is superb.
Even though the Aera 5XX only has a single serial port, when you connect a GDL39, the second serial port on the GDL39 acts as a pass through port for the original port so you can continue to drive an autopilot even after you add the GDL39.
The bare wire mount can be surface mounted to your instrument panel without having to buy a third party panel mount, so you can snap the unit in/out with ease (by pressing a button) if you choose to do so.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 10-07-2015, 05:53 AM
rolivi's Avatar
rolivi rolivi is offline
496 shows the weather nicely with either XM or GDL39. (I have both)
I use XM for music and GDL for weather on the 496.
GDL is bluetooth to the iPad so that's where I'm looking for charting and traffic.
Is the traffic display significantly improved on the Aera?
Rob
RV-6A (Purchased)
2019 Dues Paid, of course
Old 10-07-2015, 07:23 AM
g3xpert's Avatar
Post
Hello Rob,
We are glad you are happy with your 496, but you might want to check your XM subscription. We suspect the 496 is showing XM weather since it cannot show FIS-B weather from a GDL39. This is explained in the Compatibility section of the GDL39 manual.
We support ADS-B traffic on the 496 from a connected GDL39, but it is a bit more limited. As explained in the GDL39 manual, the 496 is limited to showing 8 traffic targets.
The Aera 5XX provides support for up to 30 targets, provides Target Trend information on the traffic page, and shows the Flight ID of ADS-B Out aircraft. Additionally it shows the status of the TIS-B service.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 10-07-2015, 10:08 AM
my Aera 510 has been rock solid.
