Go Back   VAF Forums > Regional Forums > International
Old 02-11-2019, 09:00 AM
JoopSJ's Avatar
JoopSJ JoopSJ is offline
Default Builder info from France, Germany, Austria and Sweden requested
Hi all,
As a board member of the Dutch Amateur Builders Club, I need some information on the EAB regulations in several countries in Europe.
I would appreciate if someone could provide next information.
I have made one thread for each country I need information on.
[duplicate threads deleted and title edited to combine all deleted threads into this one; S. Buchanan, moderator]
Building:
- Inspection during build:
- If yes inspecting authority:
- final check for airworthiness by whom:
Flying:
- Basic instruction allowed on EAB? Restrictions?
- VFR by night allowed?
- if yes, requirements?
- IFR allowed,
- If yes, requirements?
- Does the regulation state you have to avoid polulated/ build-up areas?
Maintaining:
- Can the builder perform maintenance?
- Can non-builder perform maintenance?
- Can builder sign-off inspections or annuals?
- Can non-builder sign-off annuals?
Import
- can you import half finished kits from the US or other EU states?
- can you import finished aircrafts from the US or other EU states?
I would be very thankfull if I could receive any relevant documents:
joop
sintjago.nl
Thank you very much.
Empennage ... Done
Wings ... Done
Working on fuselage
Donation 2017/2018 . . . Done.
Chairman NVAV (EAA chapter 664 - Dutch experimental aircrafts builders)
Member EAA
Member AOPA
Old 02-11-2019, 02:14 PM
control control is offline
I am the current chairman of the board for Chapter 222 and EAA Sweden. (the reason for us having two EAA organisations in Sweden is because we have a delegated authority regarding many areas concerning amateur built aeroplanes. This was not in accordance with the US EAA organisation so we splitted ourselves into two organisations despite that we act as one)
Building:
- Inspection during build: Mandatory by a person assigned by the Swedish EAA before the start of the build, usually suggested by the builder. Needs to have some relevant experience.
- If yes inspecting authority: Yes, can be done by the CAA but normally as stated above by someone appointed by the Swedish EAA.
- final check for airworthiness by whom: By an approved EAA inspector, we have about ten at the moment. Not sure at the moment but I think these persons also have to be approved by the CAA after being nominated by the Swedish EAA.
Flying:
- Basic instruction allowed on EAB? Restrictions? No, but if this is approved by EASA in the upcoming wote, it will be ok in Sweden also.
- VFR by night allowed? Yes
- if yes, requirements? Same equipment as for normal GA aircraft
- IFR allowed, Yes
- If yes, requirements? Same equipment as for normal GA aircraft, here we have a grey area as to what instruments/avionics need to be TSO/ETSO approved
- Does the regulation state you have to avoid polulated/ build-up areas? No
Maintaining:
- Can the builder perform maintenance? Yes
- Can non-builder perform maintenance? Yes after a special EAA training and after having helping out at two 100h/annuals (approved for a specific aircraft)
- Can builder sign-off inspections or annuals? Yes
- Can non-builder sign-off annuals? Yes after a special EAA course and after having helping out at two 100h/annuals (approved for a specific aircraft)
Import
- can you import half finished kits from the US or other EU states? Yes
- can you import finished aircrafts from the US or other EU states? Yes
You must be able to show that it has been amateur built and if it is of a type not already existing in Sweden then you have to have the design approved before it can be registered, sometimes easy, sometimes very difficult.
Sent me a PM with a mail address and we can discuss what you want and how to get them to you.
RV-14 kit #140138
Flight testing
Http://magnusrv.blogspot.se
Old 02-13-2019, 06:23 AM
JoopSJ's Avatar
Default Thank you
Very useful and exactly what I am looking for.
I will contact you via PM.
Best regards,
Joop
Empennage ... Done
Wings ... Done
Working on fuselage
Member EAA
Member AOPA
Old 03-09-2019, 12:28 AM
High_Flyer's Avatar
High_Flyer High_Flyer is offline
Default In France
Hello,
I Have built and now fly a RV-7 in France.
Here is what I can tell you:
Building:
- Inspection during build: Yes, one before closing the wings, one before 1st flight
- If yes inspecting authority: OSAC https://www.osac.aero/index.php
- final check for airworthiness by whom:same as above
You must first open a file with OSAC (delegated by the French DGAC for homebuilts amongst other things) and to obtain a file number and if you whish to reserve your registration marks.
Flying:
- Basic instruction allowed on EAB? Yes Restrictions? I don't know...
- VFR by night allowed?Normally no
- if yes, requirements? Very complicated to obtain, must demonstrate to the authority that the equipment and systems are compliant
- IFR allowed Normally no, same as above
- If yes, requirements? Same as above
Maintaining:
- Can non-builder perform maintenance? Initially no, yes after meeting certain requirements
- Can non-builder sign-off annuals? Initially no, yes after meeting certain requirements
Import
- can you import half finished kits from the US or other EU states? NO
- can you import finished aircrafts from the US or other EU states? NO
Contact the Vans Club de France for further info http://vansclubdefrance.fr/index.html
We have our annual fly-in on 14-15-16 June, in Pont sur Yonne near Paris. I suggest you come and talk to us it's a great week end:http://vansclubdefrance.fr/fly-in-pont-sur-yonne.html
Pre-registration is recommended if you whish to come.
regards
RV7 (F-PRVZ), Tip Up, Aerosport IO-375, Dynon Skyview, VP-X, Day VFR.
Flying since June 2017.
Old 03-11-2019, 12:11 AM
JoopSJ's Avatar
High Flyer, thank you very much for the info. Very use full.
The fly-in weekend is noted in my agenda.
I will let you know if I am able to attend.
Best regards
Empennage ... Done
Wings ... Done
Working on fuselage
Member EAA
Member AOPA
