Old 02-11-2019, 07:16 AM
Freemasm Freemasm is offline
Default Tank/rib/spar joint
I'm building an F1/F4 utilizing modified RV4 wings. The joint at the tank/rib/spar is of some concern. The tank/wing splice doubler extends from top spar cap to bottom spar cap and offers some WX protection. It stops short of the spar cap for obvious reasons. This would be a water ingress point straight to the spar. I have ideas regarding sealing this area but would like to solicit more. Much thanks.
Old 02-11-2019, 07:37 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Leave it alone. 10,000 flying RVs aren't having a problem.
Taken to the extreme, there is such a thing as too much "sealing". Remember, you are also sealing moisture in, which condenses, then evaporates, in a loop. That is much worse for your airframe than if you let the air circulate freely.
Just look at the inside of a thermal pane window with a broken seal. The water isn't friendly, not even to glass.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold
