Old 02-11-2019, 10:31 AM
MS1095 MS1095 is offline
I am a fan of the no hole yoke it tight spots.
Old 02-11-2019, 11:01 AM
Brantel's Avatar
Brantel Brantel is offline
I have ground the nose of my yokes to match the radius of the largest diameter dies I have.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 02-11-2019, 02:42 PM
fl-mike's Avatar
fl-mike fl-mike is offline
^^^^ Brantel speaks from experience.
Grind that nose.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage in progress.
Old 02-11-2019, 02:58 PM
rapid_ascent rapid_ascent is offline
I find that I have more control with my Tatco hand squeezer. In general I try to use it versus my pneumatic squeezer. Also, make sure you check the length of your exposed rivet with a gauge. A rivet that is too long will bend over. For -4 rivets I have to use my pneumatic squeezer.
When using the pneumatic squeezer make sure you keep the plunger aligned with the axis of the rivet. You can feather the trigger a little to position the squeezer slightly but it can be difficult. Usually you hit the trigger and you get what you get. If you have the plunger side on the flush side of the rivet it takes care and practice to get a perfect shop head. Try feathering the trigger so that you can make sure you are still aligned along the axis of the rivet as you get close to compressing the rivet.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Rolled the Fuselage
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 02-11-2019, 04:28 PM
maniago's Avatar
maniago maniago is offline
Kudos to you for sticking with the squeezer for so long.
But the gun and a tungsten is way more forgiving (better?) for -4 rivets and larger. I only use my squeezer on -3s and smaller (if I use it at all), and yeah everything the guys said above will help you if you remain wedded to your squeezer.....but you dont have to.
Mani
MustangII (FoldingWing) "Finishing up": IO360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,Navworx; SteamAlt,AS,VSI
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Jan2019
Old 02-11-2019, 04:39 PM
Aero_Octaveus Aero_Octaveus is offline
I too sometimes have to struggle with my squeezer. Sometimes its a bit temperamental. (I too am using the Isham adjustable rivet set) I have good success with setting AN426 rivets as getting a good set is all in getting the die perfectly flat on the factory head, and making sure the rivet tail is centered on the die before squeezing. Squeezing AN470 rivets are sometimes a bit more tricky as it is more difficult to get the cupped rivet set sitting perpendicular and square on the factory head. No question that I have better success bucking (And you become a master if you skin the wings yourself)but it can be a bit hard on light material with a 3x gun. Sometimes I've started bucking the AN470 rivet with a hit or two and then squeezed it to finish it off. Always turns out perfect that way.
Garet Hess - Edmonton, AB
RV-7A - Emp and Wings Done. Working on fuse
2018 Donation Current
http://garetsrv.blogspot.ca/
Old 02-12-2019, 06:23 AM
djborko11's Avatar
djborko11 djborko11 is offline
I too had the same problem starting out. One thing that helped is to secure the work piece so it can't move when you squeeze. Another tip I came across here is to the scuff the surface of the set, a sidewalk worked great.
D.J.B.
RV-14A #140356
East Aurora, NY
Empennage in Process
Old 02-12-2019, 08:09 AM
control control is offline
Like said, the heads look fine, but do not be afraid to hit the front of the yoke with the grinder. It is the aircraft that should look great when you are done, not the tools
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 02-12-2019, 08:17 AM
BillL BillL is offline
I absolutely hate grinding on a nice tool, but in this case it is/was necessary. It will not fit or leave a mark otherwise. The material removed is not a stressed area.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 02-12-2019, 09:02 AM
bobnoffs bobnoffs is offline
with my pneumatic squeezer i have noticed that setting the rivet with the face of the die perfectly square to the shop end of the rivet does not make as nice a finished rivet as slightly moving the back of the gun in the direction of the closed side of the c yoke. i suppose this is because of a little flex in the 3''
3'' yoke.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12.
RV-12 kit as of 9/13
