Old 02-03-2019, 03:27 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Default Homemade base antenna?
Im looking for a cheap solution to get a handheld radio to have better reception inside a metal hangar. Any ideas of a low cost solution?
Rob Lasater
Rv-14 still workin
Paid nov 2018
Old 02-03-2019, 03:49 PM
rv7charlie rv7charlie is online now
Kitplanes has had probably a dozen different base station antenna designs over the years. A stroll through their archives should give you plenty of ideas.
Old 02-03-2019, 03:50 PM
Brantel's Avatar
Brantel Brantel is offline
Hard to beat a copper J pole if you have somewhere to mount it.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 02-03-2019, 05:04 PM
wirejock's Avatar
wirejock wirejock is offline
Simple. 1/2 wave antenna.
Get a piece of copper rod 3'-10 1/4" long.
Solder it to the center lead of coax. You can use a piecebof PVC to hold it or fabricate something fancier. Works great with #12 Romex too.
Make four equal length rods for a ground plane. Cinnect all four and solder those to the shield of the coax. Four sections of any metal will work. Copper pipe, rods, etc.
Should be resonant at 121.500 Mhz.
Leave it up to you to make the mount.
I've made antennas with aluminum arrow shafts too.
Makes a great lightning rod so don't have it connected during a storm!
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-03-2019, 08:35 PM
N804RV's Avatar
N804RV N804RV is offline
Here ya go. You can tune it to optimize for airband. Instructions are on the website.
https://vk2zoi.com/articles/half-wave-flower-pot/
Ken W.
Mount Vernon, WA
2018 VAF Supporter
Old 02-03-2019, 09:15 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Here is a short video on making a 2meter antenna. Just cut the lengths to 127.5MHz and you are good to go for the Aviation band. I have built 10-15 of these over the years and if done correctly will have about a 1.2:1 VSWR across the entire band. It is a very easy project to complete.
Building a 2meter base antenna
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2019 Dues Paid
www.PuertoRicoFlyer.com
Old 02-03-2019, 09:30 PM
wjb's Avatar
wjb wjb is offline
This is a good design; I've built many of these, too, with good effect. I've soldered the ground plane radials (downward sloping wires) rather than using the screw method. It will save a few $0.01's
Be sure to mount it OUTSIDE the metal hangar; on a 3-4 ft+ pole above the roof would be about perfect.
Bill Bencze
N430WB RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
Old 02-11-2019, 12:19 AM
Av8rRob's Avatar
When mounting a 1/4 wave ground plane antenna on the roof of the hangar, do i need to worry about the metal mount/hangar grounding the antenna? Should I somehow try to isolate the antenna from the ground? Does this matter?
Thanks guys.
Rob Lasater
Rv-14 still workin
Paid nov 2018
Old 02-11-2019, 06:59 AM
GalinHdz's Avatar
Thanks guys.
Nope. Just make sure none of the radials or the active element touches the metal hangar and get the antenna as high as practical above the top of the hangar. FWIW I mounted mine using a 8' long pressure treated 2x4 piece of lumber and it works great.
Galin
CP-ASEL-AMEL-IR
2019 Dues Paid
Old 02-11-2019, 07:21 AM
RV6_flyer's Avatar
I had a homemade airband antenna that worked well at KCCB when I had a hangar there.
I am now using one of these tuned to 122.975 and it works perfect for the same amount of money had I made my own. I have it mounted the way it says here with PVC pipe but have a hook in the ceiling of my hangar with it hanging inside.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
