POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
01-30-2019, 12:51 PM
What else to do before I attach the tailcone?
Hey - quick question. I am quickly approaching the section in the build where the instructions have you attach the tailcone to the fuselage.
I am planning on installing my static tubing before attaching the tailcone, but wondering what else I should be thinking about before the joining begins
Jason
Jason Tremble RV-7A (Flying)
IO-375, Hartzell Prop
Garmin G3X Touch, VP-X Pro
RV-10 in process (SB Fuselage)
01-30-2019, 12:58 PM
Wiring for the tail light/strobe, trim wiring, antenna coax?
01-30-2019, 01:59 PM
AHRS platform if you are planning on putting it back there.
ELT antenna wiring. I used a larger conduit strung a bit loosely so no strain would be put on the cable if the rear fus. crumples a bit.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
01-30-2019, 02:33 PM
If you are just attaching the tailcone there isn't much you really need to worry about. But, before you rivet the top skins on you will want to think about the wiring (strobe, rudder trim if applicable), static tubing, AP servo mount(s), and possibly magnetometer. You might also consider cutting/installing the naca vent if you plan on using overhead vents.
Darin
Snoqualmie WA
RV-9A Flying as of 03/2015
RV-10 Building - Fuselage
www.DarinAnderson.com
2018 donation sent!
01-30-2019, 08:53 PM
Gil,
Any particular reason you, "used a larger conduit?"
Mike
RV-10 Emp Kit! Here we go!! Woo-Hoo!!!
DUES REMINDER: DEC 2019
01-30-2019, 10:33 PM
Originally Posted by MJarreau
Gil,
Mike
Yes, so the cable is a loose fit in the conduit. Stuff a little extra cable in it too...
You don't want a nicely tied down tight co-ax strapped to a j-stringer that could get crumpled in an accident.
Gil Alexander
02-05-2019, 01:29 PM
Looking ahead, in a few steps the instructions have you install the rudder cables. Any reason not to put them in the tailcone before it is attached to the fuselage?
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
