Old 08-26-2017, 12:41 PM
shoprat shoprat is offline
Default BRS Chute Installation for RV10
For those interested in installing a BRS chute in their RV10, I have some good news. Several builders, including myself, have signed purchase agreements which has gotten the design and engineering phase started. Should see the first kits by the first of the year or before. I'll send updates as the process progresses.
Bruce McGlamery
Winter Springs, FL
Old 08-26-2017, 03:19 PM
raabs raabs is offline
Interesting...any approximations on weight of the system?
Rob Kelly
FL
Old 08-26-2017, 04:02 PM
Default BRS Chute for RV10
No. Too soon. They just got the aircraft into their CAD engineering software. Will be a couple of months before we see any details.
Bruce
Old 08-26-2017, 04:06 PM
Electrogunner Electrogunner is offline
Default Chute
Very interesting. I'll keep an eye on this one. It will be neat to know how this can be done using existing structures in the RV10. I can imagine the weight penalty will be substantial.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV
Garmin G900X
First Flight 2/14/2019
Old 08-27-2017, 08:58 AM
soloff soloff is offline
I'm interested as well if the weight and CG stays reasonable
Scott
Fuselage and tail attached. Working on Fuel&Brake lines
Build Log - www.oloff.com
2018 Dues Paid
Old 08-27-2017, 09:29 PM
TimJRV10 TimJRV10 is offline
Default I'm Interested
I'm interested too! My brother suggested I buy a used Cirrus instead of building the RV10 due to the 'chute. My empennage kit is ordered. Having the BRS chute would be a big plus!
Donation made for 2018
Old 08-27-2017, 09:47 PM
Default Curious
I have always been curious as to the reasoning behind the chute. Not to start a primer war but here is a discussion question:
What would be a valid reason to pop the chute?
I'm curious to see what people would consider dire enough to use it...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 08-27-2017, 10:10 PM
OkieDave OkieDave is offline
Originally, it was included because the Cirrus can't recover from a spin--the ability to recover is a certification requirement, so the FAA allowed the BRS as an alternate means of compliance.
Beyond that, I think it's the tool of last resort any time a pilot gets in over his head. The Cirrus is a very high-performance aircraft, and we all know what happens when you mix that with a pilot who can't stay proficient; think "fork-tailed doctor killer."
Old 08-28-2017, 07:15 AM
Night, over mountains, lost engine with oil on the windscreen, and blue haze in the cabin......
Bruce
Old 08-28-2017, 07:25 AM
KatanaPilot KatanaPilot is offline
Default Not entirely accurate
I think you can easily find data to refute this statement. I believe the issue was more that the SR-20/22 did not meet the Part 23 recovery guidelines and the CAPS was installed as the AMOC. The DA40XLS with winglets did not meet the spin recovery requirements either, so the winglets were never delivered on these aircraft.
From Part 23 -
A single-engine, normal category airplane must be able to recover from a one-turn spin or a three-second spin, whichever takes longer, in not more than one additional turn after initiation of the first control action for recovery, or demonstrate compliance with the optional spin resistant requirements of this section.
Check out the article from COPA here.
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction
