Old 04-15-2016, 07:25 AM
stamper stamper is offline
Default scat tube reducer
anyone know where to get a 2" to 1 1/2 or 1" reducer for the inside cabin heat to run back to the back.
Also can anyone tell me if we have to have the 100LL sticker around the fuel caps in order to get the plane inspected by the DAR.
2016 dues paid
RV10 Started Jan 2013
DAR sign off April 23rd 2016
PA-18
PA-46
Cessna 172 and T182RG
Old 04-15-2016, 07:54 AM
Raymo's Avatar
Raymo Raymo is offline
I've seen red RTV used to fill the gap between tubes of different sizes. Seemed to work well.
Another thread on fuel cap labeling suggested you only need the amount of fuel in each tank on the label. Lots of folks run non-ethanol MOGAS.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 04-15-2016, 08:52 AM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
Plane Innovations has the scat tube adapters.
Since I just got my pink slip last week, I know you need to have quantity and minimum octane rating on your tanks.
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Chief
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
Race Coordinator STOL Drag coming to Reno, 2019
"so I got that going for me... which is nice."
Old 04-15-2016, 08:54 AM
So, sounds like congrats are in order
Old 04-15-2016, 09:20 AM
Bluelabel's Avatar
Yeah, I need to get off my butt and upload the obligatory photo. 😜
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Chief
twin turbo, IO-540,
Old 02-11-2019, 03:51 PM
cderk cderk is offline
Just wanted to resurrect an old thread to see if anyone has any other sources for ther 2” to 1” reducer. Sure enough, PlaneInnovations has them. $25 each, which is kinda steep, but once I saw they wanted to charge me almost $18 for shipping, i decided to try to find an alternative. Unforuntately I don’t see anyone else carrying something like this.
Charlie
RV10 - #41673
http://n688cd.wordpress.com
N688CD Reserved
Old 02-11-2019, 05:26 PM
Andrew Anunson Andrew Anunson is offline
Default Adapters
Since its in the cabin, not the engine compartment, can you use adapters for workshop dust collection systems or for shop vac hoses?
Carefully check dimensions of the hoses you plan to use as well as the adapter you find to make certain the parts fit before you spend the money.
Old 02-11-2019, 05:36 PM
Bill Boyd's Avatar
Default roll your own?
How difficult to make out of fiberglass over a modeling clay plug, for instance?
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 02-11-2019, 06:43 PM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
You can easily make almost any adapter combination you need by bying 2 Aeroduct flanges from Wicks and riveting them together.
Carl - - Morrison, CO
N16CB RV7A
Airworthiness cert issued 12/24
best X-mas present I could have hoped for!
paid 'til 10-19
Old 02-11-2019, 08:26 PM
gasman gasman is offline
Go here..... https://www.aircraftspruce.com/catal...clickkey=49081 and pick the two sizes you want connected.
Glue the flanges back to back, grind down the flange to look good, connect scat. Total...$19 plus shipping.
VAF #897
2019 =VAF= Dues PAID
