Old 02-05-2019, 07:45 AM
mbishop mbishop is offline
Default RV-10 Wing Spar Shim Question
I'm about to start riveting my wing skins on and I was wondering how exact I have to be with the main spar being level to the table. I have some wood blocks underneath that get me pretty close to level when it is clamped down.
Should I get my level out and ensure X and Y are both level w.r.t. to main spar? Do you think that the pre-punched holes in the wing ensure that there is no warping in the final product?
2019 Donation made.
Riveting left wing together (RV-10).
Old 02-05-2019, 07:48 AM
rleffler's Avatar
rleffler rleffler is offline
The pre punched holes are just fine.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 02-07-2019, 12:24 AM
paul330 paul330 is offline
When I skinned my wings, I set the spar up on 4 saw horses and shimmed it until everything was level. When I finally fitted the wings and clecoed the rear spar hole, I measured the @#$% out of them and found that they were not as much as 1/16" out anywhere. Final drill the rear spar bolt hole and move on......
Now, it's possible that I am simply an ace builder or that the pre-punched holes would have done the job anyway...........
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 02-07-2019, 01:00 PM
longranger's Avatar
longranger longranger is offline
With the wing skins clecoed on, just make sure the inboard and outboard ends of both spars are all parallel with each other.
I didn’t trust mine to come out square, so I borrowed a set of adjustable wing stands so I could clamp the wing in place and adjust out any twist before drilling.
http://www.mykitlog.com/users/displa...150366&row=198
It also made a handy fixture for riveting the top skins.
http://www.mykitlog.com/users/displa...=161654&row=89
Miles (VAF# 1238, Paid up as of 2018)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on site
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
