Old 09-04-2019, 08:08 PM
AirHound AirHound is offline
Default Nose gear fork SB/fairing conversion
Calling old hands! Can the old nose wheel pant fit and be converted for the newer SB fork without as much disassembly the conversion part kit calls for? Just piecing it together I’m hopeful to just add the mounting flanges to the new fork and then only match drill the new fairing flanges and doublers to the old pant. Am I dreaming?
Doug
Doug
Old 09-05-2019, 03:05 AM
noelf noelf is offline
If I am understanding your question correctly, then yes, the "new" nose wheel pant brackets can be riveted to the nose wheel pant. The brackets will mount to the old fork or the newer "cut down" fork.
Have you already cut down the nose wheel gear leg and rethreaded the end for the new nose wheel fork?
Noel
RV-6A N6NF
tip-up
flying
Old 09-05-2019, 04:07 AM
Dang, I just got the box of parts in the mail and was piecing things together for the project. The rv12 is 30 miles up the road still with OEM nose gear configuration. I thought the gear leg would go through the new fork hole w/o modification/no cutting or rethreading. Didn’t see cut down instructions yet in the KAI. What does newer ‘cut down’ fork mean?
So, one can’t just slide the old fork off and new on, as simple as that? And to make sure I understand you about the brackets, I’m thinking only remove the two top doubler plates which are on top of the bent brackets which are riveted to each side of the wheel pant and then only rivet the two new plates back on the brackets with three new match drilled holes. And that’s all I was going to replace just those two flat pieces. Yikes, I got to cut down and rethread the gear leg?
Doug
Old 09-05-2019, 09:49 AM
OOPS!!
I did not see that you were talking about the RV-12. My comments were for an RV-6A and the like.
I have no experience with the RV-12.
Noel
RV-6A N6NF
tip-up
flying
Old 09-05-2019, 09:26 PM
Itís been over a year since I put he new fork on, but I donít recall any issues fitting the fork or wheel pants. I eventually pulled the wheel pants off to simplify maintaining tire pressure.
Old 09-05-2019, 09:27 PM
Did you notice a loss in knot's air speed during cruise?
Old 09-06-2019, 07:37 AM
DaleB's Avatar
DaleB DaleB is offline
Not having the nose wheel pant on cost us a few knots -- sorry, I don't remember exactly how many. Less than 5, but enough that we noticed.
I wasn't able to see a way to get the wheel pant to fit without replacing the brackets. Maybe someone else has been, but I don't see how. And yes, it's kind of a PITA, but not insurmountable. I just reminded myself that it's the inside of a wheel pant, so no one else will see the botched but structurally sound rivets.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 09-06-2019, 12:08 PM
Thank you but I think I can just only drill and replace the doublers that sit on top on top of each bracket. Then all Iím doing is just riveting those off and new ones one with three new attachment screw holes on top which go through the new doubler and existing bracket. What do you think Dale?
Doug
Old 09-06-2019, 12:40 PM
DaleB's Avatar
No idea if that will work or not, sorry. I did mine last winter, and after verifying that the wheel pant wouldn't fit unmodified I just followed the directions.
That's rare for me, but it does happen occasionally.
Dale
Omaha, NE
Old 09-06-2019, 03:24 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
It will not work, shape of nose fork is different. Easy to do as in the plans and nothing you do damages any paint.
Scott- 2020 donation
New RV-7A N579RV, finally over 40 hours... the leash is off
Built RV-12, 328 hours-sold, purchased RV-12 sold, Built RV-9A, 536 hours-sold, Not completed RV-7 sold, Built Kitfox sold
