Old 01-04-2019, 12:35 PM
Cirrus Man Cirrus Man is offline
Default RV-12is Improvements in a RV-12
Has anyone installed some of the "many" improvements made to the RV-12is in their RV-12?
* New throttle quadrant design
* Quick reacting electric flaps
* Quick adjust seat back feature
* New cup holder
* Dual USB power outlets
* New transversely mounted fuel tank
* Improved canopy latch design
* Cockpit handle on panel
* Stick grip options for trim control, PTT function, AP disconnect
* Dual Landing Lights
* Improved steps
Old 01-04-2019, 12:54 PM
rvbuilder2002's Avatar
* New cup holder
* Improved steps
The bottom 5 are definitely retrofitable.
The rest (except USB ports) would be challenging to add to a ULS fuselage.
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
Old 01-04-2019, 02:45 PM
jpflys1 jpflys1 is offline
the latch revision also, no?
Old 01-04-2019, 03:08 PM
Oops... edited post to say bottom 5.
Scott McDaniels
Hubbard, Oregon
Old 01-04-2019, 03:34 PM
DaveLS DaveLS is offline
Headset hangers
Roll bar brace inside supports
Flush canopy deck rivets
Voltage regulator to upper firewall with dedicated cowling vent
Old 01-04-2019, 07:09 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Main landing gear seals per KAI 38iS/U-10/11
This would make a nice retro-fit kit, for those of us not wanting speed fairings.
Tony
E-LSA RV-12 ULS
Old 01-04-2019, 08:46 PM
pilotyoung pilotyoung is offline
Default Mods
I installed the dual USB ports on my panel and a Tosten stick grip with PTT, ident, auto-pilot disconnect, and pitch trim on it.
John D. Young, RV-12 Owner
Serial Number 120022, N6812Y
Bought it as a flying airplane in Feb. 2018
Just passed 240 hours flight time in RV-12, and 10,000 hours mostly in corporate jets. I am a CFI; CFII; MEI; and a advancd Ground Instructor, CFIG; and hoping to be able to help new RV-12 owners by doing some transition training for new builders and owners in RV-12's.
Old 09-29-2019, 07:47 PM
Retrofitting a RV-12IS fuel tank into an RV-12. Any one thought about it or done it? How difficult and what is involved in removal and replacement?
Old 09-30-2019, 04:38 AM
joe gremlin's Avatar
joe gremlin joe gremlin is offline
IIRC there are some posts in the mods thread that show an early 12 with a full width tank behind the seats. This was years before the iS was thought of so he obviously fabricated it from scratch rather than using iS parts. So it can be done that way but I wouldn't expect it to be easy. And obviously it would require certifying as E-AB unless you change it after the plane is built and flying.
The thing that would make me nervous is that it involves the modifying the fuel system. When you look NTSB reports in regards to the experimental side, it seems to paint a picture that deviating from the plans/factory design of the fuel system increases your chances of experiencing an in-flight engine stoppage significantly. That's across all experimentals not just the -12. But regardless its evidence enough to show me that the fuel system is not something I'd be too keen on mucking about with. Proceed carefully.
Joe
RV-12 Empennage
Fuse kit in box
Need a wing kit
Old 10-06-2019, 08:26 AM
HansLab HansLab is offline
I installed the Cup holder (including a wooden box that falls over the wing roots - an early idea from one of the Forum members, WAY before the iS was sold).
I also installed the headphone holders and put the VR both beneath the avionics tray, put in grip switches for trim, build the cockpit latch and put on the the hand grip (pax only).
Good ideas are there to be copied!
Hans Labruyere
build & sold project Kitfox IV
Project bought & building RV12 #120742
Donation 2020 paid
