Old 10-08-2019, 07:03 AM
Bruinpilot Bruinpilot is offline
Default Scotchbright wheel
Iíve noticed vans and some tool supply outlets only sell 6 inch scotchbright wheels. I have an 8 inch grinder. Do they make 8 inch wheels, or can. 6 inch be safely used on an 8 inch grinder?
Old 10-08-2019, 08:22 AM
Desert Rat Desert Rat is offline
the biggest difference is that the guard that you typically rest the work on won't be up close to the edge of the wheel. Most people take those guards off for polishing wheels anyway.
two other considerations:
1. The size of the shaft on your grinder. The wheels from Cleaveland normally come with a 1/2" bushing, so if you have a bigger grinder with a 5/8" shaft, you have to specify that you want those bushings instead.
2. RPM. There's a max RPM for those polish wheels and I don't remember off the top of my head what it is, but you should be able to look it up easily enough. Just make sure your grinder can spin it slow enough that it's not going to grenade the wheel.
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing #72651
Old 10-08-2019, 08:39 AM
Thanks for the good info. Iíve been thinking about taking all those guards and rests off anyway. I think my grinder runs at 3850 rpm. I will definitely look into he max wheel rpm. Thanks for the reminder on that!
Old 10-08-2019, 09:01 AM
jcarne's Avatar
jcarne jcarne is online now
Yep as long as the mounting shaft is the same size you will be good to go. The first thing I did was take the guard off, it would be massively in the way if it was still on.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
Old 10-08-2019, 12:18 PM
mturnerb mturnerb is offline
I like the buffer from Harbor Freight for Scotchbrite wheels - the spindles are longer, and no guards to get in the way. Much easier to to maneuver longer pieces while deburring/shaping. I also used their stand to mount it - again better than bench mounting as stand can be moved into position to maneuver long pieces. I shamelessly stole the idea from Synergy Air when I did their class.
Buffer: https://www.harborfreight.com/power-...fer-61557.html
Stand: https://www.harborfreight.com/univer...tand-3184.html
Turner Billingsley
RV-14A FLYING, N14VB
Old 10-08-2019, 08:29 PM
Maxrate Maxrate is offline
My scotch bright wheel is about to play out after eight years. I think I got it from AveryĎs Whatís the best one on the market now?
Mark Malone, RV7
Wings complete, SB 14 complied with, fuselage in progress.
N442MM reserved
http://www.mykitlog.com/MikeMike
2018 Donation gladly paid.
Old 10-09-2019, 02:39 PM
Also, Iím just curious, can a belt or disk sander with the right grit do the same job as the scotchbrite wheel?
Old 10-09-2019, 04:59 PM
The wheel smooths and deburrs edges without taking much material, and the work piece can be easily manipulated. Hard to have this much flexibility and fine control with sander.
Turner Billingsley
Old 10-09-2019, 06:36 PM
N941WR's Avatar
N941WR N941WR is offline
I would Chuck the wheel in my drill press set to the slowest speed.
That gives you greater access to the wheel than a bench grinder.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
