Old 11-23-2017, 09:36 AM
N546RV's Avatar
N546RV N546RV is offline
Speaking only for myself (but I'm pretty sure this is the same thing AX-O is doing): I use the NAS1097AD-3-X rivets for nutplate attachment. So it's still a #40 hole, but with a smaller countersink needed than if I was using a "regular" flush rivet. The countersink is shallow enough that I generally do it by hand; it just takes a few turns of the deburring tool.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
https://www.meetup.com/Houston-Area-RV-Enthusiasts/
Old 11-23-2017, 09:50 AM
maniago's Avatar
maniago maniago is offline
Exactly what I do. Deburring tool will make the proper depth counter sink hole and you can just get away with it in .020 skin if youre wicked careful. Funny thing tho, my last order of 1097s from Vans was 1 lb of rivets. They called me and asked if Id flipped my lid. Clearly I suck at building if I need that many. The young lady had not heard of using them for nutplates, so we had a good laugh. In anycase, that order was my 3rd 1097 order, each bigger than the last and I finally got fed up ordering the things so ordered enough for the next two planes nutplates!
Mani
MustangII (FoldingWing) "Finishing up": IO360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,Navworx; SteamAlt,AS,VSI,wet compass
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Jan2019
Old 11-23-2017, 11:56 AM
Christopher Murphy Christopher Murphy is offline
Default If its an oversize rivet?
If its an oversized shank how does it go into the #40 hole on the nutplate and if the head is undersize how does it fill a normal #40 countersink or dimple?
Cm
RV-4 "Mr. Twister"
Pitts S1S "Mexican Red" sold and missed
Mr. Twister Airshows
Rocky Mountain Renegades
the mission... have fun.
Old 11-23-2017, 01:15 PM
vlittle's Avatar
vlittle vlittle is offline
Cm
Oversize shank = undersize head. The NAS1097-AD3 3/32" rivets have a smaller head than regular AD3 rivets.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 11-23-2017, 03:23 PM
Thanks for the info. Now I have it figured out.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 11-23-2017, 04:02 PM
maniago's Avatar
Cm
Yeah, its oversized for a -2 rivet hole that you goofed on. Except we never build with -2 rivets; we use -3s, 4s and 5s. IOW, it has a 426AD-2 head with a -3 rivet shank.
Mani
N251Y (res)
Jan2019
Old 11-23-2017, 05:18 PM
With a small diameter female dimple die, you can dimple the nut plate holes and the skin. I found that doing that actually helps keep the nutplate screw hole aligned with the hole in the skin. No special rivets needed.
Old 11-23-2017, 06:12 PM
Larco Larco is offline
HOLD ON? I have used the small head oops rivet for nut plates as well for years BUT I think the oops rivets Vince is offering is NOT that rivet. It is a standard head 3/32 or 1/8 size head with a over sized shank. Instead of an 1/8th in shank on a 3/32 head oops rivet it now is available in a smaller than 1/8 shank requiring a smaller oversized hole. If I'm wrong, pound away. :-)
Old 11-23-2017, 09:19 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Thanks Larry. You are exactly correct. I guess I should have made this clear and we could have avoided the thread drift! My bad.
The rivets in question here are NOT NAS1097 series and are not worth a darn for installing nutplates. They are for fixing a goofed rivet WITHOUT drilling it all the way up to the next rivet size... thereby not needlessly enlarging the rivet hole. A much better fix in my humble opinion.
Mini-Oops Size - Repairs this Rivet - Mini-Oops shank diam. - Original Rivet Diam.
NAS1241AD3-3.... AN426AD3-3.................... 7/64"...........................3/32"
NAS1241AD3-4.... AN426AD3-4.................... 7/64"...........................3/32"
NAS1241AD4-4.... AN426AD4-4.................... 9/64"............................1/8"
NAS1241AD4-5.... AN426AD4-5.................... 9/64"............................1/8"
Clear as mud now!
Sorry about the table format scrunching. I think you can figure it out though.
Anyway, get them from Blake at www.flyboyaccessories.com
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 11-25-2017, 09:02 AM
Marc Bourget Marc Bourget is offline
Slightly swelling a rivet is helpful in assembly when skins (particularly "formed" shikns) don't fit "exactly."
You can either pre-swell, or insert and "swell" (takes practice). Then follow up by "drawing" the skin together with a bucking bar that's been countersunk with a larger center hole. VERY light, very slow tapping with the rivet gun will pull the skins together and then you can drive the rivet in full.
