Old 04-15-2019, 01:19 PM
JwWright57 JwWright57 is offline
Default Install rudder pedals before side skins?
Hi all - it seems like it would be easier to install the rudder pedals before putting on the fuse side skins. However, the pedals are further down the build chain. Do the side skins HAVE to be put on first?
Has anyone gone this route?
Jeff Wright, Charlotte NC
Rv-12 started!
Tail 99% done
Wings 99% done
12IS fuse kit 99% done
Finish kit is Here!! 50% done :-)
Dues paid 2020
Old 04-15-2019, 06:02 PM
Dave12 Dave12 is offline
You can install the rudder pedals on the shelf and then rivet and seal the shelf in place. Makes it very easy to install them.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Old 04-15-2019, 10:32 PM
I flecked the side skins until I was done with the cockpit to ensure I had easy access to everything.
Old 04-16-2019, 07:36 AM
John-G John-G is offline
I riveted the rear portion of the side skins but left enough unriveted that the skin could be pulled back enough to allow access for installing the rudder pedals without distorting the skins. It worked just out just fine and made the instillation slightly easier than I think it would have been had the skins already been riveted in place.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2020
Old 04-16-2019, 02:21 PM
joedallas's Avatar
joedallas joedallas is offline
Default No Side Skins
I agree
Take a Look no side skins
http://joesrv12.com/Builder%20Log/bl_32_02.htm
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 04-16-2019, 04:06 PM
Jamesey Jamesey is offline
Default Side skins
Had the side skins on, donít recall this being any issue.
Old 04-16-2019, 09:50 PM
rcarsey rcarsey is offline
Originally Posted by joedallas View Post
I agree
Joe Dallas
Joe, I looked at your log.. you didn't use that DOT3 brake fluid did you? DOT3/4 eats O-rings (and paint). DOT5 is supposedly ok.. as is the usual Mil-H-5606
Old 04-17-2019, 06:37 AM
joedallas's Avatar
Default 56606
The drop of brake fluid I used to install the insert was all that I had at hand at that time.
I used 5606 from Aircraft Spruce to fill the brake system .
https://www.aircraftspruce.com/catal...?clickkey=4008
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
